ATF for power steering fluid
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Do it just like the trans, remove the return hose at the reservoir, pump into a container, replace as you go, maybe a half-liter at a time. two to three cycles should have clean fluid in the whole system
Current Volvos:
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Ouch....that stuff needs to be flushed out.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1609 times
Been thanked: 4065 times
misha wrote: 21 May 2018, 09:26 It MUST be red.
Im concerned the Reds are contaminating our Precious Volvo Fluids.
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 23 times
Been thanked: 4 times
Post by Danonly55 »
Ok thanks guys, 1 last question, which hose is the return ?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
Isn't there only one hose on a pre-1999 - I thought the reservoir fed the PS pump directly??
Danonly55
Post by Danonly55 »
The fluid some how has to get back to the reservoir, I watched a vid on the pump change and there was 2 lines.
" John Wayne
The big heavy line will be the high pressure line down to the rack. The one that looks like regular hose will be the return line. The fittings on the pressure line are swaged with a metal fitting, the low pressure line just a clamp (either a hose clamp, a Jubilee clamp, or one made by Oetiker of the Oettinger Clampett Family (for erik)
Danonly55
Post by Danonly55 »
Thank you so much !!! Off to getter done.
" John Wayne
