doing a PCV replacement
Archer
- Year and Model: 2002 V70/S60 T5
- Been thanked: 5 times
That's a good idea, torx head bolts. Also, just discovered this...the 10mm socket from those cheapo toy-like socket kits are shorter by 3mm - 4mm, and it can even be reduced quite a bit with a belt sander of sorts. Can make your own custom "stubby" socket.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Here's a tiny 3mm socket I turned in a sherline lathe to make it fit a controller board in a Ford.Archer wrote: 23 May 2018, 18:31 That's a good idea, torx head bolts. Also, just discovered this...the 10mm socket from those cheapo toy-like socket kits are shorter by 3mm - 4mm, and it can even be reduced quite a bit with a belt sander of sorts. Can make your own custom "stubby" socket.
Next day at AutoZone I see they sell the special slim socket doh.
- dlundblad
- Year and Model: 2002 S60 2.4t
- Has thanked: 6 times
- Been thanked: 4 times
I started the job late afternoon on a Saturday and didn't finish until Sunday evening, but this was working very slow and many breaks.
If you get the crankcase breather pipe, (I recommend you do because the old one broke on me when I tried taking it off), my advice is to get a lower radiator hose as well. I had to cut the old one off to get to one of the banjo bolts near the firewall. The banjo fitting on the intake manifold is 17 mm IIRC and a swivel ratcheting wrench really helps. Get the crush washers if you get this line.
May not be a bad idea to at least buy the anaerobic sealant and the oil cooler seals if you end up needing to remove the pan to clear the lower passage.
I ended up buying many oeitiker clamps and the installation tool that honestly I didn't even need. The tool was too bulky to get into most areas. I think I was only able to use it on the flame trap elbows and that was because I put everything together with it off the engine. I ended up using worm gear and fuel injection hose clamps mostly.
Hers: Charcoal 2002 S60 2.4t 187k
- Has thanked: 1611 times
- Been thanked: 4075 times
I clamped my lines up off the car. The last one to do is the banjo which I did with the intake manifold loose. That one was toughest
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
I am part way in, and ready to start removing the manifold. My fuel line comes up between the two intake runners and makes a sort of U turn to accommodate a coupling, then it finally connects to the fuel rail. I see some vids that show the intake manifold being moved to one side, but can I do that with mine, considering the way the fuel line is run in my car?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
You gently bend the 90 degree to a 45, keeping the radius large so you don't kink it. You have to release it from the fuel rail of course - usually with a tool or a split Bic pen.
azureblue
how and where do I release it from the fuel rail?abscate wrote: 25 May 2018, 12:58 You gently bend the 90 degree to a 45, keeping the radius large so you don't kink it. You have to release it from the fuel rail of course - usually with a tool or a split Bic pen.
And is there an O ring in the power steering pump Line fitting? I found shredded piece of something green wrapped around it when I unscrewed it from the pump. If so, what size is it and can I use a hardware store O ring?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Archer
Power steering o-ring is #969092. If the original was shredded, it was on too tight...do you have the lock bracket that attaches to the coupling that attaches the hard line to the power steering pump?
You can't just swing the manifold up and over to the side, unclimbed the fuel lines with a fuel line quick disconnect tool from Harbor Freight. You have to manipulate/rotate/tilt the manifold to get it out from the 90 degree bend.
Pull the fuel rail off..as in pulling the injectors out of the manifold. You should really take the time to replace the injector o-rings, filter baskets and clean injectors. Also, I'm quite sure your vacuum hoses could stand to be changed....5mm and the 10mm, maybe an 8mm, too. Just doesn't make sense to address and clean items as you go, well worth it.
azureblue
Yeah, it was on too tight. Don't know if I can get to the dealership Sat. morning to get the O ring. Or even if the parts dept is open Sat. I may have to find it at an auto parts store, Lowe's, etc. Vac hoses are all good - PO replaced them. And I have to have the car running by Tuesday, so, withe the dealer closed I may have to do injectors later. Thanks though.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 798 Views
Last post by dmack87
- 15 Replies
- 2791 Views
Last post by SonicAdventure
- 2233 Views
Last post by JMEngland88
- 24 Replies
- 4930 Views
Last post by petermetzger
- 849 Views
Last post by 98v70dad
