A/C cold for 10mins then goes warm.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
scot850 wrote: 25 May 2018, 23:33 Issue in my opinion is as stated on the clutch gap. That was exactly what my car was doing last year. When the outside temp was about high 20's C, it was ok, but as soon as it went over 30C it would run for a while then go warm. Switch it off and leave for a while and the it would do it all over again. Clutch gap was way too wide.
I'll take a look now, thank you for your input.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Has thanked: 1613 times
Been thanked: 4078 times
You have to look at the compressor pulley , the part that ouches the serpentine belt always turns, the outside face turns when the clutch is pulled in, and stops when the clutch is out
If you lose cold air and the outer face is still, it’s probably a clutch gap problem
shiloh51933
abscate wrote: 26 May 2018, 09:36 You have to look at the compressor pulley , the part that ouches the serpentine belt always turns, the outside face turns when the clutch is pulled in, and stops when the clutch is out
The clutch disengages when it's blowing warm air.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
should be a gap issue or an issue with the charge/compressor. but gap is the first thing to check/fix just give it a check or post a pic , if it looks like 1mm it's too much
shiloh51933
shiloh51933
