Brakes work, but booster doesn't
Chasma
Year and Model: 1994 850
Post by Chasma »
When I brake while driving, the booster starts, but gives out almost immediately, so I have to basically stomp on the pedal to actually stop. I tested the hose going to the booster, there's no leak.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
sitting still do you hear a big chuff of air when you push the pedal?
normal failure mode is a hole in the diaphragm. Other way is hole in the outer housing, like rust-through.
Current Volvos:
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
Just out pf curiosity: is it a gas powered volvo or one with the audi diesel? The diesels have a vacum pump that goes bad. I just had that on my VW Multivan.
1996 855 R,
2010 V70 D5,
Chasma
Post by Chasma »
FLXC90 wrote: 27 May 2018, 14:44 sitting still do you hear a big chuff of air when you push the pedal?
It sounds more like a squeaky toy could that be the same thing?
Chasma
Post by Chasma »
Clemens wrote: 27 May 2018, 15:37 Just out pf curiosity: is it a gas powered volvo or one with the audi diesel? The diesels have a vacum pump that goes bad. I just had that on my VW Multivan.
Thanks, but it's gas powered.
FLXC90
Post by FLXC90 »
If you have a helper, one press brake, one listen for where the squeaker is. use a length of tubing as a stethoscope if necessary, to really nail it down, unless it is obviously inside the can. (booster)
Current Volvos:
