99 s70 awd, p0756
Clopez91
Year and Model: 1991, Volvo S70 Awd
Post by Clopez91 »
Hi guys im new to this forum. I have been doing research but not have a solid solution here. My 99 s70 awd have the notorious flashing arrows, scanned for fault dtc and founs the following, p0756, p0722. Now p0756 is shift solenoid b stuck off, and p0722 output shaft speed sensor, Now i cant really find shit solenoid b, the only at any part store looks like they only sell one shift solenoid and it does not seem to be the one. Also wouls like to know if p0722 can be causing this issue. Vehicle shift 1st and 2nd after clesring code fine but when going into 3rd gear it bangs gear hars and then vehicle goes on limp mode. I hope someone can help. Thank you
Yarddogperformance
Year and Model: 2000 v70 cc se
Has thanked: 2 times
Post by Yarddogperformance »
Solinoid stuck off means no fluid flow. , Search eBay, and if possible the boneyards, a trans shop is going to want to sell you a new trans, so if you find your solinoid and it does not fix it, than 1 of to this is wrong
1. ( Worst case) the trans is bad and there is an internal fluid leak
2. The wiring is bad and it lost either a power or ground connection
What is the part number for the solinoid? I'll give a look, I'm against part stores
Clopez91
Post by Clopez91 »
Was also thinking wiring. But where in the wiring im looking at? In the valve body or outside the trans?
Been thanked: 4069 times
Try the Volvo parts lisle site for part numbers. I’m not sure they drill into transmission that deep but it might.
///and fix your Car description when you get a chance or else Mecum will be calling to auction off your rare 1991 S70
πŸ€”
Checked...lisle shows two solenoids for sale....go there
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
C: how about when you manually shift the car, or try S mode button? Has the fluid been checked/changed? May be past that point, but cheap first step.
Current Volvos:
Clopez91
Post by Clopez91 »
So i was doing some more research, and sae that there could be a possible tcm or pcm update. Along with transmission drain and fill. Will be calling my local volvo dealer. But i dont want to drive the car like that so i might have to tow it there, if they say there is an update. Also i dont know if this year have a tcm reset apperently that also can fix it. As the transmission apperently was replaced before. Eill keep posted until i find a fix. As it seems this is a com6on issue but no one ever really post on how they ended up fixing it. Or if they fix it. Thanks guys
Clopez91
Post by Clopez91 »
https://www.ebay.com/itm/VOLVO-850-854- ... OSwYRhanFb~
does this seem like a good deal or should i just buy new ones?
Clopez91
Post by Clopez91 »
also been seen alot of people say pnp? can it really be a pnp?
Clopez91
Post by Clopez91 »
Anyone have a good idea?
