How to bleed air from power steering system
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 23 times
Been thanked: 4 times
Post by Danonly55 »
Changed the power steering fluid in my 96 850 and its foaming and the steering seems a little rough. How do you bleed air out ?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Typically it self bleeds with use. Make sure it's not low.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
I usually put the front end on jacks, open the reservoir cap, and with the engine running, will then cycle lock-to-lock numerous times.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Has thanked: 2207 times
Been thanked: 1852 times
+1 with ecbsykes.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Agree cycling lock-to-lock a few times with engine running and cap off or resting on top of reservoir should push through any air as the pump pushes fluid and the lock-to-lock cylcing pushes the fluid through the lines.
Danonly55
Post by Danonly55 »
Thanks Everybody, I have cycled the system twice now and will do again tomorrow, feels better already.
" John Wayne
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Cycle the wheel all the way both ways before starting the car in the morning before the fluid becomes foamy. Check the level before starting as well. That was the process for Ford's many years ago and it worked. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
June wrote: 30 May 2018, 08:06 Cycle the wheel all the way both ways before starting the car in the morning before the fluid becomes foamy. Check the level before starting as well. That was the process for Ford's many years ago and it worked. June
It's hard work turning the wheel with the engine off ;-)
I've myself just driven the car at low speed turning back and forth between the end points and it's done the trick so far. If it foams it'll take a while but every time it gets a bit better and a bit less foamy.
June
Post by June »
Rattnalle wrote: 30 May 2018, 08:11
I guess it depends if you want better, or fixed :wink: June
My Volvo cars owned
1996 960 ordered
Rattnalle
Post by Rattnalle »
June wrote: 30 May 2018, 08:26
I meant every turn of the wheel gets better. I've never had more air than two or three turns each way or so to get it back to normal. Just disconnecting the pump doesn't seem to let very much air in.
