Does anybody know where Headlight wiper motor wiring harness is, I can't seem to find it.
I want to keep the OEM look and leave the blades but disable just the passenger wiper motor which has a mind of its own where it finds its park position.
Thanks
- Has thanked: 2211 times
The wires for the motors has a join that is clipped just above the headlights. It is usually a brown connector with a push wire to disconnect.
In the lower part of the picture you can see a brown connector not connector to anything. That is the headlight wiper motor connector. Just below it to the right you can just see the edge of the connector it should clip into under the edge of the slam panel in the same color.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
For posterity and clarity, is the circle the correct connector?
Thank you Scot!
Thank you Scot!
- RH side of 2000 V70 NA engine bay 001 2.jpg (302.3 KiB) Viewed 1955 times
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
That is one half. If you look slightly lower to the edge of the slam panel and just to the right of the with cable label you can see the other part where it plugs into. It is the same color. The connector you have circled it the cable end leading to the motor itself.
mecheng
Thanks Neil, not Scot, my mistake. Still rocking the amp you sold me!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
You may also need to undo the water hose to the headlight wiper, it looses quite a good amount when spraying the windshield.
Not sure where it's connected to the reservoir.
You can remove it from the wiper arm and just tie a knot in the end of the pipe and tuck it behind the panel.
Glad the amp is working well!
mecheng
Ya, I had the arm removed, but didn't have the motor removed so I got tired of that look and wasn't ready to remove it completely for any future buyer. I like the look of the wipers, and maybe if I keep the liquid connecting it should clean the headlight from the wind pressure. Tieing a knot is not a bad idea, I had some electrical tape.scot850 wrote: 30 May 2018, 10:43 You can remove it from the wiper arm and just tie a knot in the end of the pipe and tuck it behind the panel.
Thanks all
