Moisture in distributor cap
Scratchy2000
- Year and Model: v70 xc awd 1998
I have a Volvo v70 1998 wagon and I believe that I have moisture in the distributor cap as the car cranks but won't spark in and shortly after rain. I really don't want to spend much money as the car is on its last legs. Can I put heat resistant tape around the seals are does anyone know of another quick fix? Thanks in advance.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
pull the cap and wipe it out. maybe smear some wax on the cap flange. Do a glove test,
Current Volvos:
- Been thanked: 4068 times
A Nitrile glove has four fingers and a thumb - so if you cut one more hole for the coil wire you have a perfect Volvo waterproofing sleeve.
- Has thanked: 316 times
- Been thanked: 531 times
Try to see where there is water getting into that area. Being that there's no seal on the cap, you probably won't have to worry about changing any of that.
Might be worth pulling it anyway to check for oil, your cam seal may be leaking.
+1 to smearing grease on the cap to head flange.
- 2295 Views
Last post by Sommerfeldt
- 9 Replies
- 2396 Views
Last post by obayha
- 34 Replies
- 15972 Views
Last post by FLXC90
- 37 Replies
- 7159 Views
- 1015 Views
Last post by bmdubya1198
