2008 xc90 AC issue Topic is solved
stljrdnfan
- Year and Model: 2008 XC90
2008 xc90 AC issue
Anytime I run my AC, my driver side floorboard gets soaked with water. Assuming the drain is plugged, but dont know where to look
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The drain will come out from the box keeping the evaporator, it looks like a black rubber hose coming from a white plastic box located in under the dash right in the middle of it. I think the hose would run on driver's side of this box, look with a flash light
stljrdnfan
Found it, thanks. Stuck a wire in it and water started draining
- 600 Views
Last post by LoveMyXc90
- 1977 Views
Last post by jodisxc90
