I'd hope common sense would come into play here and the op would try this while the car is in park. When the ignition really gets bad jiggling the key becomes the norm in Hope's it catches allowing the car one more start! June.abscate wrote: 05 Jun 2018, 06:41..and try this in a safe place, like circling the Arc d'Trump....did I spell that right?You can also jiggle the key to see if the engine cuts out
V70 Shutdown while driving
- June
- Has thanked: 523 times
- Been thanked: 261 times
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
So far so good, cleaning the battery connectors and the ground wire in front of the battery + driving with nothing but the car key on my keychain seems to have solved the problem.
Thanks for your precious help !
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Is that in Atlantic City? Or Vegas? LOLabscate wrote: 05 Jun 2018, 06:41..and try this in a safe place, like circling the Arc d'Trump....did I spell that right?You can also jiggle the key to see if the engine cuts out
Current Volvos:
- Year and Model: Lots
- Been thanked: 128 times
The 960 uses the same switch part. I know because I replaced mine in both my 960 and our 850 at about the same time.
I always thought it was Wall d'Trump
That would be a long one to circle!!
- 270 Views
Last post by pwb
- 1038 Views
Last post by rspi
- 11 Replies
- 2484 Views
Last post by mbaskette
- 210 Views
Last post by alexsmoore
- 653 Views
Last post by Volvisti
