2001 volvo s80 2,4
When I push to brake pedal i see writing: check brake light.
Sometimes to shine only the top stop-signal, sometimes all 3 lamps, any lamp sometimes doesn't shine. Always there is an inscription "check brake light". If posible problem in swich under brake pedal? I need brake light circuit ?
Yuri
2001 volvo s80 check brake light
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Just guessing, but I would expect the switch at the pedal to be working since it actually activates the message. Could it rather be an issue with the cables to the bulbs? Maybe also ask on the S60 forum, the S80 forum does have users but much less.
Here's a video if you want to inspect the brake pedal switch
There was everything simply - the relay doesn't work.
But it is strange that brake light works even at the removed socket from brake pedal switch now.??
The brake pedal switch 2001 volvo s-80 is under a cowl. And it have resistance in the pressed provision of a brake - 200 ohms, in not pressed - 1500 ohms.
- 9 Replies
- 6595 Views
- 2860 Views
Last post by Georgeandkira
- 2319 Views
Last post by oragex
- 9 Replies
- 4161 Views
Last post by ndphotonl
- 10 Replies
- 3066 Views
Last post by JLGParis
