Am I screwed
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Xemodex is certainly an option but sloooooowww!!
Contact either Doublebug or Yagger (both of them are forum members)
They can clone the original CEM over the internet for small dollars. Yagger or Doublebug will send you a small OBDII tool (that you can keep if you like) that does the keys and the rest is done with Dice. Doublebug and I have programmed around 9 or 10 CEMs over the internet and our latest was a 2005 2.5T XC90
If you plug in the original CEM and go to Network can you still see software versions in Vida?
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Communication error:
Use the standalone DiCE diagnostic to test the hardware. Look in the start menu under DiCE.
Where did you get the copy of VIDA you have installed?
What version(s) of .Net Framework do you have installed?
What version of Windows?
You are in the US, you need to change the partner group from INT to AME.
INT (International general)
AME (North America ... USA, Canada, Mexico and Puerto Rico)
EUR (Volvo Cars Europe)
NOR (Volvo Cars Nordic Countries)
Active
Past
exzile9
Year and Model: 2005
Has thanked: 5 times
Been thanked: 3 times
Post by exzile9 »
Does anyone know any of any possible solutions to the message I'm receiving on Vida? ( Problem Shown in the pictures above)
exzile9
Post by exzile9 »
Ok I may have found my problem with Vida working. The computer is running 64-bit Windows 7pro, while the device driver is a 32-bit version. Does anyone know where I can download a 64 bit Vida device driver?
RickHaleParker
32bit is not the problem. All DiCE drivers are 32bit and they work on 64bit systems.
If you think there is something wrong with the driver, go to the disk or .iso \3PP\Products\DiCE and run SetupDiCE.exe It will re-install the correct driver.
Active
Past
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
exzile9 wrote: 07 Jun 2018, 16:29 IMG_20180607_141759.jpgIMG_20180607_141805.jpg
I think you need to enable IE Hosting.
SOLUTION: Locate on your VIDA DVD the directory D:\Install\Utils (substitute D: for your actual VIDA DVD location) and the file "EnableIEHostingx64.reg" and merge it with the registry by double clicking on it and then select "Yes" and "OK". For x86 systems do the same with "EnableIEHostingx86.reg" Windows Registry Editor Version 5.00
If you are comfortable editing your registry, you can manually make the entry. The directory in the registry should exist - you will need to add the variable. Use whichever is appropriate:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MICROSOFT\.NETFramework]
"EnableIEHosting"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework]
See if that gets it talking.
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
RickHaleParker
Did you use the VIDA2014D_RePack.iso and the install instructions I posted?
Active
Past
exzile9
Post by exzile9 »
Hey how's it going folks, thanks for all the replies. I now have a used cem, and working installation of Vida. What I need now is the procedure for copying the old cem and reinstalling the data on the new one. Any points towards the right direction are appreciated thanks.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
exzile9 - I sent you a PM, but before chasing that route, are you using a like for like used CEM? Did it come from an XC90 of the same year and same engine/transmission configuration?
exzile9
Post by exzile9 »
This one's a 2005xc90. the doner was a 2006 xc90 same vehicle from comparing the vin and options.
