Rattle Sound in front left over bumps - not with brakes applied
lostmyVcardXC
Year and Model: 2004 XC70
Post by lostmyVcardXC »
New to the Volvo world but couldn't pass up this '04 XC70. Runs, drives and looks great with only 117k on it. Owner I got it from seemed meticulous in his care, had extra bulbs for the entire vehicle, bumper dye (another question I need to research) and other small miscellaneous things for it that he included.
When I test drove it, I heard a metal type rattling sound in the front left when going over bumps. By all accounts I can say it's not affecting the vehicle in any way. Steering is tight, full turning radius available, suspension seems reasonably stiff for the miles. If I go slow enough, say over a speed bump in my neighborhood the sound is non existent. Also, when applying the brakes, but still maintaining speed over bumpy roads the sound disappears. This leads me to believe it has to be a caliper issue? Any ideas? I researched this on the website, but I didn't see any mention of the sound disappearing when the brakes were applied so I figured I would make a new thread for it.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Could be a brake dust shield. Take the wheel off and have a peak. It could be bent, rusted out or loose. If I recall it is held in place with two 10mm short bolts.
A loose caliper would affect braking in my mind.
That is where I would start. While the wheel is off I would look at all the suspension parts in that corner if it is not the brake dust shield.
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
MDK here..so, reading your post..a rattling sound could be a few things. I've been messing with Volvo's for a good while. It could be the following: the front strut itself or sway bar links.. common problem or the upper spring seat or a sway bar bushing or caliper... it's what I call getting the front tires hanging and get big pry bar and see what's loose. Sounds like a good wagon.. good mileage..
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
If you suspect the sway bar link you can disconnect the bottom end and tie it out of the way, then drive the car.
mrbrian200
Been thanked: 84 times
Post by mrbrian200 »
I would check the condition of the caliper guide pin sleeve/bushings. 'Goes away when braking' is sort of a telltale sign. Most if not everything else that might make a rattle wouldn't go away when the brakes are applied.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
It was the dust shield on mine, a mounting hole was wallowed out. Easy fix with a fender washer.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Can you maybe record and upload it on Youtube? By rattle, do you meat it's like 'vibrating' not just a single knock? Maybe turn the wheel and have a look first at the spring, the XC70 is known to break one once in a while. Just a quick check. Then the brake shield may rattle if the garage forgot to tighten the bolts.
lostmyVcardXC
It's not a vibration. It's a knocking type of rattle. I'm about to tinker with it and see what I can come up with. I'll keep you posted.
MDK
Post by MDK »
So I read your last reply and to me it sounds like an upper spring seat .. very common because Volvo uses recycled materials for their rubber components... I couldn't tell you how many Volvo I bought with this issue..
lostmyVcardXC
MDK wrote: 11 Jun 2018, 05:31 So I read your last reply and to me it sounds like an upper spring seat .. very common because Volvo uses recycled materials for their rubber components... I couldn't tell you how many Volvo I bought with this issue..
So I didn't get a chance yesterday to tinker. Is the idpusa.com website the move for parts like what you mentioned above?
