This forum has discussed the replacement heater core distributed by Swedish Car Parts at great length, which is decidedly a great product. Notwithstanding the quality of this product, some Volvo enthusiasts have experienced coolant leaks at the juncture between the heater core and the coolant pipes. The great members of this forum have posited a number of theories and fixes to this problem––chiefly that, OEM O-rings are necessary and that the O-rings provided are of insufficient thickness and/or quality. I respectfully disagree.
I believe the root cause stems from the design of the plastic bracket connecting the aluminum pipes to the heater core. The reliance upon a single machine screw to uniformly tighten and seat the O-rings results in one of two scenarios: i) an O-ring will be pinched or ii) the brass collar will pull free of the plastic bracket before a seal can be obtained. Each results in a leak.
I found that by discarding the T25? screw and utilizing a 4mm screw with a 7mm bolt and washer, I was able to avoid either of these scenarios. The washer helps to distribute force during tightening and provide an even O-ring seal, and the bolt prevents the brass collar from pulling out.
This simple fix enables an assuredly tight seal with the O-rings provided by Swedish Car Parts.
You will need:
4mm screw
7mm nut
2 flat washers
1/4" drive socket
deep 7mm socket
short 7mm wrench
Note: When installing the screw I found it necessary to use the deep socket to reach it's head due to the narrow gap between the plastic molding on the heater core.
Heater Core Pipe (Leak Fix)
VolvoAffair
- Year and Model: 1998 S70
- Been thanked: 4 times
- Has thanked: 1611 times
- Been thanked: 4072 times
Maybe a Nylock bolt or a dab of Loctite blue to keep that in place?
If you hacksaw off the cm of extra thread, it will be easier to reinstall, too
Great observation on the O rings
VolvoAffair
That's a good point, thanks!
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Nice writeup.
I preemptively replaced my original heater hoses last year and decided to just buy a new OEM coupler. The old one basically fell apart as I removed the heater hoses, so it was a good call.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
We thank you for adding To the collective IQ!:
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Looks great. Bet this will fix the minor intermittent leak I was getting late this winter/early spring.
2023 Lexus RZ450e -66k
- 5099 Views
- 11 Replies
- 9901 Views
- 1360 Views
Last post by callahanoffroad
- 1352 Views
Last post by Hil
- 32 Replies
- 17899 Views
Last post by sleddriver
