IPD sale Volvo Parts
Did you know? 🤔
Regreasing strut bearings in place
2001 - 2007 XC-70
Rattnalle
Has thanked: 14 times
Been thanked: 100 times
Sweden
Rattnalle
Post by Rattnalle » Mon Jun 11, 2018 6:38 am
oragex wrote:
Sun Jun 10, 2018 6:45 pm
Speaking of grease, it's also easy to pack the strut bearings, this way it will last the life of the car www.youtube.com/watch?v=Pnoy6ixh2WA
So this post above in another thread reminded me of something I've been thinking of since my car is making strut bearing rattles and squeaks and I'd very much like to put off replacing it for a little while more without having to listen to it.
Has anyone tried or think it's possible to reach the bearing with spray grease to quieten it for a while? I'd be quite prepared to drill a few small holes in the plastic cover up top if that's what it takes.
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 14 times
United States of America
MDK
Re: Regreasing strut bearings in place
Post by MDK » Mon Jun 11, 2018 11:00 am
I may be wrong.... isn't that black plastic cover a dust cover that pops off?
Rattnalle
Sweden
Rattnalle
Post by Rattnalle » Mon Jun 11, 2018 1:32 pm
As far as I can tell its the bottom part that pops off downwards after the bearing has been removed from the strut.
Georgeandkira
Year and Model: 2007 V70 base
Has thanked: 11 times
Been thanked: 32 times
Georgeandkira
Post by Georgeandkira » Mon Jun 11, 2018 3:09 pm
I just went out to look at mine and while I'm not dead certain of the dimensions (exact location of the ball bearings) it looks like your drill bit would punch into the raceway and leave burrs. Gauging one of the balls or having it jam against the raceways is a possibility.
I lubed mine when I changed the struts. We had a spray can of a clear, viscous grease which shot in perfectly. Check with a picture of one in a catalog and see if you can sneak some lube in. You won't damage anything if you overshot (drown it in lube).
mrbrian200
Has thanked: 7 times
Been thanked: 72 times
mrbrian200
Post by mrbrian200 » Tue Jun 12, 2018 9:20 pm
I don't know about it lasting the live of the car, at least in northern road salt zones. The flat part you can't see up at the top of the wheel well is a rust monger. I replaced one that had play in the bearing when I bought the S60 2 years ago (8 years old at the time). The amount of rust/corrosion on the one I replaced was kind of extreme. I don't see the other one holding together but for a few more years. It's on my preemptive strike list to replace the other one sometime this year or next.
SuperHerman
Has thanked: 0
Been thanked: 97 times
SuperHerman
Post by SuperHerman » Wed Jun 13, 2018 3:09 pm
I don't see an effective way to regrease without pulling the strut assembly. If you catch it in time you can regrease them, the bearings are pretty visible if the strut is out. But as mrbrian200 states the wheel well is a rust monger and the bearings have little to no sealing other than the grease. If you take it out and it is rusting already - best to just replace them.
I suppose you could try spraying something thick if you disconnect the top three mounting bolts and push down to gain additional access. Maybe you will get some added life.
oragex
Year and Model: S60 2003
Has thanked: 77 times
Been thanked: 155 times
Canada
oragex
Post by oragex » Wed Jun 13, 2018 5:03 pm
I've seen these at the junk yard with 1/2 of the plate remaining and almost paper thin from rust. But the worst part is this metal plate sits right over the coat of the strut tower (the chassis metal): once this plate starts rusting it eats the paint/coat and starts chewing into the strut tower from underneath www.youtube.com/watch?v=a3gNNboxytg
Side note, careful not to get grease on the three studs, tightening the nuts with grease on the studs may come with some surprise.
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
Rattnalle
Sweden
Rattnalle
Post by Rattnalle » Thu Jun 14, 2018 2:11 am
I'm not worried about the plate. It and the surfaces it touches plus the entire rest of the wheel housing with the plastic taken out were covered in rust inhibitor by me when I last had the strut out. It's the bearing itself thats squeaking. But it's little enough that I'll probably just ignore it until after the holidays.
