Fuel pump relay or fuel pump? 99 s70 t5
speedyt5
Year and Model: s70 t5, 1999
Post by speedyt5 »
I just bought the whole replacement kit that comes from FCP for the fuel pump assembly. I just replaced the relay and now the car is running fine. Do I bother so replace the fuel pump now since car is running fine. Maybe just hold on to the kit for a while before I send it back in case the pump goes? The guy on the phone said that the relay probably went because the pump caused it to and eventually the pump will need to be replaced, but then again I don't think I have ever replaced the relay, so why couldn't it just be the relay and nothing else? Thoughts?
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
I wouldn't replace the fuel pump if it works fine now.
85 GLH, 367 whp
00 Insight, 72 mpg
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Send it back if you can, you can always order it again.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1836 times
Been thanked: 1709 times
Fuel pump relays work hard for a living. If the pump works fine and isn't noisy, send the pump back like Clemens suggests.
speedyt5
Post by speedyt5 »
The question is, "How loud should the fuel pump be?" I can definitely hear it running from the rear of the car.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
With engine running...you shouldn't hear it,unless it is a performance pump or on it's way out...or you're low on fuel.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 292 times
Been thanked: 765 times
Many of the aftermarket pumps are loud and can be heard from the cabin when the engine is running. By itself that doesn't tell you much unless you know it is a A Bosch pump, those are pretty quiet on the other hand.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1497 times
Been thanked: 3810 times
send it back, unless you know where the low fuel light is on your car.
210k on my original fuel pump and relay now
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
I had intermittent issues with no start that were a fuel pump relay and/or a plugged fuel filter. When the filter was disassembled there was no noticeable buildup. You can bypass the relay temporarily for troubleshooting purposes but I wouldn't drive it daily like that.
161k on orig. fuel pump. ~135k on that previous fuel pump relay.
