Connecting Pins 87 To 30 To Start Car - Continuos Clicking With Ignition
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Just moved the other XC70 form the yard and need to move it back. Now, at the turn of the ignition to start, I hear continuous clicking until I release the key. This I feel would be the starter . . . right? Since am not ready to tackle that now, can I just do the connecting the Pin 87 to Pin 30 to start the car, just to move it back to the yard? If yes, how is that done. Maybe I did not search well enough, but, need a good instruction on how to do the pin connections and on which relay.
Thanks.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
If the starter is clicking, check the battery.
Active
Past
Oka
Post by Oka »
I have the battery a full charge right before starting it again. I remember (maybe it’s a Volvo thingy) sometimes a new battery is some solutions. Though this battery is about six years old. Will try another battery. Will send an update. Thanks for the info.
RickHaleParker
When you think you have a full charge, take the battery to Autozone and have them bench test it.
If the battery sat for a long time without a float charger, good chance it has a heavy build-up of lead sulfate crystals. It is possible to recover a newer battery from sulfation but, six years old ... the odds are not good but not impossible.
Active
Past
Oka
Post by Oka »
I got another older battery, fully charged it and it started the XC. I have moved it back to the backyard to deal with it latter. Thanks for your info.
RickHaleParker
Store the battery/batteries on float charge (trickle lowest amperage) as a peventive measure to avoid this problem again. I have taken batteries that where in bad shape and restored them with a long float charge. It might take weeks on float charge but it not like it is needed now.
Active
Past
