Dumb question but need to ask
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
My '98 S70 is on it's last leg and I was changing the front left tire to put on the spare and I stupidly did not chock the rear wheel
and the car rolled forward and came down on the rotor. It broke the tie rod at the joint. My stupid question is can I drive the car for a short distance without causing any more damage?
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Mr. Detail wrote: 16 Jun 2018, 09:57 It broke the tie rod at the joint. My stupid question is can I drive the car for a short distance without causing any more damage?
I wouldn't.
85 GLH, 367 whp
00 Insight, 72 mpg
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Too high of risk to reward. Have it towed.
Active
Past
Has thanked: 1609 times
Been thanked: 4064 times
Maybe out to the street to get it towed, or 1000 yards to a local shop at 5 mph at 0300 hours.
If the tie rod separates, the wheel will flop inward and stop you short, hard.
Mr. Detail
abscate, the tie-rod is already separated from the lower point of contact. Kind of like a ball joint connection.
If it is snapped off inside the tie rod end, the car is stuck and needs towing.
If it broke the nut off, you could clamp it and crawl it somewhere, and I mean 5 mph or less.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Nah.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
