Volvo S80 V8 2008 CV boot squeaking?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Which of the sides is the one that does this (the resistance thing) ? Just thinking if it's on passenger side, it may be the carrier bearing on the axle.
oragex
Post by oragex »
ThommyKent wrote: 16 Jun 2018, 01:28 Any roughness is not acceptable, that`s a sure sign of needing replacement. A lighty loaded bearing will squeal when dry. The driveshaft bearing in my old 240 squealed so bad it would draw the attention of pedestrians.
I put a used bearing on mine about 15000 miles ago, it had a slight roughness at some point, it is still good today... but it was a genuine one. These take long time to fail, so it's a matter of optimizing the expenses in the end. The car can have many parts with some wear on them that will last for more years. Just my point of view.
And I also did ride on a car that had a front bearing with serious play (and consequently noise) in it, it didn't squeal at all. The driver was actually nervous about it seizing at any moment given the state of wear. I'm guessing these will start squealing just prior to seizing?
Jackazz
Year and Model: 2008 S80 V8
Post by Jackazz »
The resistance is on the side that squeaks.
ThommyKent
Year and Model: 91 245 97 850 T5
Been thanked: 5 times
Post by ThommyKent »
oragex wrote: 16 Jun 2018, 08:00
Usually they just rumble ever louder and squeal as they seize up like you said.
oragex
Post by oragex »
Jackazz wrote: 16 Jun 2018, 08:04 The resistance is on the side that squeaks.
Which side is this?
Jackazz
Post by Jackazz »
Drivers side. Left side.
oragex
Post by oragex »
Let us know how it went
Jackazz
Post by Jackazz »
So today i brought my car to the shop to get the bearing replaced.
The mechanic said that its definitely not the bearing and didn't replace it (He told that the noise is not a bearing noise). But he also couldn't locate the squeaking noise.
I'm gonna look for another shop to identify the problem..
I might also make a video of me rotating the wheel when lifted, so You guys get the general idea of what i'm talking about.
