Fuel pump relay or fuel pump? 99 s70 t5
speedyt5
- Year and Model: s70 t5, 1999
- Been thanked: 2 times
I just bought the whole replacement kit that comes from FCP for the fuel pump assembly. I just replaced the relay and now the car is running fine. Do I bother so replace the fuel pump now since car is running fine. Maybe just hold on to the kit for a while before I send it back in case the pump goes? The guy on the phone said that the relay probably went because the pump caused it to and eventually the pump will need to be replaced, but then again I don't think I have ever replaced the relay, so why couldn't it just be the relay and nothing else? Thoughts?
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Send it back if you can, you can always order it again.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 2199 times
Fuel pump relays work hard for a living. If the pump works fine and isn't noisy, send the pump back like Clemens suggests.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
With engine running...you shouldn't hear it,unless it is a performance pump or on it's way out...or you're low on fuel.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
Many of the aftermarket pumps are loud and can be heard from the cabin when the engine is running. By itself that doesn't tell you much unless you know it is a A Bosch pump, those are pretty quiet on the other hand.
send it back, unless you know where the low fuel light is on your car.
210k on my original fuel pump and relay now
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I had intermittent issues with no start that were a fuel pump relay and/or a plugged fuel filter. When the filter was disassembled there was no noticeable buildup. You can bypass the relay temporarily for troubleshooting purposes but I wouldn't drive it daily like that.
161k on orig. fuel pump. ~135k on that previous fuel pump relay.
