Reduced Engine Performance
natesvolvo
- Year and Model: 2002 S60 2.4t
Hello all. I am new to the forum. I usually read this forum for advice on how to fix my car but it seems i couldn't find a topic to fix my current issue with my 2002 S60 2.4t. I bought the car last year with 139,000 miles and it now has 144,000. I love this car to death but it has always had an issue from day 1 that the guy i bought it from couldn't figure out. Since he hasn't helped i decided to start doing my own work on the car. The issue it has had is a Reduced Engine Performance light. The vehicle will sort of stumble as it starts and sometimes throw the REP light. Not all the time. but after its started the idle is a little rough and the car seems to cough at least once while at idle in park within the first 4 minutes of starting. If the REP light illuminates its gone within 5 minutes. The car will also drive fine except it shakes a little at idle in drive. If i raise the RPM's over 3k while driving, the REP light comes back but only stays on for a few seconds then goes away. I have taken stabs at the issue by replacing: Spark plugs, Coil packs, Fuel Filter, Fuel injectors, MAF sensor and I've even cleaned out the throttle body. I have no clue what could cause this really odd behavior. Any help would be appreciated! Thanks!
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
What about getting a laptop with the Volvo diagnostics software, read the codes, it gets you a lot closer. It would have been cheaper.natesvolvo wrote: 21 Feb 2018, 17:53 Hello all. I am new to the forum. I usually read this forum for advice on how to fix my car but it seems i couldn't find a topic to fix my current issue with my 2002 S60 2.4t. I bought the car last year with 139,000 miles and it now has 144,000. I love this car to death but it has always had an issue from day 1 that the guy i bought it from couldn't figure out. Since he hasn't helped i decided to start doing my own work on the car. The issue it has had is a Reduced Engine Performance light. The vehicle will sort of stumble as it starts and sometimes throw the REP light. Not all the time. but after its started the idle is a little rough and the car seems to cough at least once while at idle in park within the first 4 minutes of starting. If the REP light illuminates its gone within 5 minutes. The car will also drive fine except it shakes a little at idle in drive. If i raise the RPM's over 3k while driving, the REP light comes back but only stays on for a few seconds then goes away. I have taken stabs at the issue by replacing: Spark plugs, Coil packs, Fuel Filter, Fuel injectors, MAF sensor and I've even cleaned out the throttle body. I have no clue what could cause this really odd behavior. Any help would be appreciated! Thanks!
natesvolvo
Well everything i changed needed to be changed. the car was not cared for before i owned it. So in my book it was money well spent. Where does one find the Volvo software online and how much is it?
- jonesg
Yeh we cant have an intelligent conversation without codes.natesvolvo wrote: 17 Jun 2018, 19:48 Well everything i changed needed to be changed. the car was not cared for before i owned it. So in my book it was money well spent. Where does one find the Volvo software online and how much is it?
I bought my version of vida from a vida forum user, installed on a laptop for 180. Add the dice interface from amazon $90.
Start here,
viewforum.php?f=40
Nate... where are you in MA? We’ve got a lot of good people who cruise the area who can read codes for you to get you started.
natesvolvo
I'm over in Bristol countyabscate wrote: 18 Jun 2018, 04:26 Nate... where are you in MA? We’ve got a lot of good people who cruise the area who can read codes for you to get you started.
- jonesg
I lived in boston for 30 yrs, the only time i heard counties was at the registry . Still dont know what county i was in.natesvolvo wrote: 29 Jun 2018, 05:51I'm over in Bristol countyabscate wrote: 18 Jun 2018, 04:26 Nate... where are you in MA? We’ve got a lot of good people who cruise the area who can read codes for you to get you started.
Is Bristol south shore?
new Bedford area - known well to us sailors...Im going to be in Providence in a week or two
natesvolvo
Im over by Taunton/Seekonk areajonesg wrote: 29 Jun 2018, 10:48I lived in boston for 30 yrs, the only time i heard counties was at the registry . Still dont know what county i was in.natesvolvo wrote: 29 Jun 2018, 05:51I'm over in Bristol countyabscate wrote: 18 Jun 2018, 04:26 Nate... where are you in MA? We’ve got a lot of good people who cruise the area who can read codes for you to get you started.
- 13 Replies
- 1558 Views
Last post by firstv70volvo
- 6247 Views
Last post by oragex
- 14 Replies
- 7211 Views
Last post by raquette
- 2995 Views
Last post by mickenann
- 1779 Views
Last post by carlsson72
