C30 Evaporator Temp Sensor Location - Where? Topic is solved
flamefront
Year and Model: 2008 C30
Post by flamefront »
Hello -
I have a 2008 C30 whose AC gets warm after 20 minutes of operation. I already did the clutch shim check and the clutch does not disengage yet the air blows warm. Refrigerant pressures are good, so it points to a bad evaporator temperature sensor. Online manuals show it being on the side of the evaporator above the gas pedal (LHD cars), but it is not there....
Can anyone clue me in as to where the C30's evaporator temp sensor is?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Active
Past
flamefront
Perfect. Thanks for posting that - I see that it is much higher up than I was looking.
Really appreciate the help
