could I have a bad motor mount?
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
PCV job done successfully now onto the next fix - I have a very short "lag" when I accelerate or decel. In addition I hear a clunk from under the hood. It acts just link a broken motor mount, at least like what previous cars I have owned have had. The upper strut cross brace seems to be loose to me. So how would I go about finding the bad mount? Thanks
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Have an assistant get in the car, start it, firmly hold the brake, drop it into gear, and give it a little throttle to apply torque to the drive train. See if the engine rocks excessively. Do this in both Drive and Reverse.
We recommend the above with automatics only, or a good supply of assistants with a standard
azureblue
Lol! or quick reflexes!. Thanks....abscate wrote: 22 Jun 2018, 13:56 We recommend the above with automatics only, or a good supply of assistants with a standard
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- June
- Has thanked: 523 times
- Been thanked: 261 times
A worn axle can cause the same trouble if the mounts are good. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
MDK here...on the motor mounts. I bought a used S60 that I'm going thru. If you're planning on keeping your car for awhile afew years anyway., Just replace them all. Volvo uses recycled material that after about 10 yrs from the heat/cold cycles and oil or whatever they get soft ...my advice anyway. On my 1998 XC 70 I replaced them and I don't think I spent more than 200$ and about 3 hours labor...if you're mechanically inclined... rolling on
- June
+1 replace all at the same time. This is excellent advice. One bad mount will in time ruin the rest. JuneMDK wrote: 22 Jun 2018, 17:18 MDK here...on the motor mounts. I bought a used S60 that I'm going thru. If you're planning on keeping your car for awhile afew years anyway., Just replace them all. Volvo uses recycled material that after about 10 yrs from the heat/cold cycles and oil or whatever they get soft ...my advice anyway. On my 1998 XC 70 I replaced them and I don't think I spent more than 200$ and about 3 hours labor...if you're mechanically inclined... rolling on
My Volvo cars owned
1996 960 ordered
1996 960 ordered
azureblue
I never thought about that - thanks. The car has a vibration around 50mph that I was blaming on out of balance tires...How to check for worn axle, then?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 16 Replies
- 3926 Views
Last post by cleven
- 4203 Views
- 1032 Views
- 31 Replies
- 5346 Views
Last post by callahanoffroad
- 1667 Views
Last post by vtl
