o5 v70r loud rumbling noise at speed
mikefoxtrot
Year and Model: 2005 v70R
Post by mikefoxtrot »
I am getting a loud rumbling noise similar to driving on rumble strips that increases with speed to point where cant talk on highway Any thoughts on my problem?
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Sounds like a CV joint is giving up.
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Hub bearings or bad tire...
mikefoxtrot
Changed from snows to performance tires and no change to noise Will look at bearings and CV joints
Appreciate the advice
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
mikefoxtrot wrote: 24 Jun 2018, 08:20 I am getting a loud rumbling noise similar to driving on rumble strips that increases with speed to point where cant talk on highway Any thoughts on my problem?
Prop shaft support bearing.
Been thanked: 4068 times
A wheel bearing will typically change noise when you swerve (careful) back and forth. Left wheel bearing noisy on right turn, right wheel bearing noisy on left turn.
Driveline noise won’t change
