Uneven brake pad wear
Brianscott
- Year and Model: 1998 volvo v70xc
Hello i got some uneven brake pad wear going on at the front brakes. The front drivers side brake pads still got plenty of meat on them, but the passenger side is completely gone now. What could cause this sort of issue?
- Has thanked: 1502 times
- Been thanked: 3817 times
Brake caliper is sticking on passenger side. If you haven't changed your brake fluid every 2 years, that is likely the cause
Brianscott
Would bleeding and changing fluid fix it?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Can we assume all pads were the same brand and installed at same time?
Could be a few things. I would go with stuck valve inside the ABS valve unit. But also check if the piston slides properly inside the caliper, if the flex hose to the caliper has cracked, if the sliding pins move relatively easily.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
If inspection reveals nothing, put the thicker pads on the opposite side, take a short break in drive, then jack up the front and check for brake drag. With excessively uneven wear, it's hard to check for drag if nothing left on one pad. A bad brake hose or sticking caliper are likely suspects. Does it pull to the side when braking? What is your driving style? If you brake hard in turns, it is possible for one side to wear more than the other, especially if you primarily make left turns. Also, what pads are you using? Cheap pads mean less quality control, which can result in uneven wear.
Knows enough to be dangerous
Brianscott
I used akebono pads and i replaced them all at the same time. I brake relatively slow not hard. Also i put a rebuilt abs module in it a year ago.
Brianscott
What is the abs valve unit?
Brianscott
Oh and also its the outer pad that is wearing and the inner pad has life in it still
Brianscott
Sounds good. Im going to get my brake fluid flushed after i replace the pads and grease the pins. What kind of grease do i use?
- 10 Replies
- 1528 Views
Last post by Shanestrait
- 9 Replies
- 2051 Views
Last post by thedancingfiddle
