Thanks for checking, I really appreciate it!
After searching the part number, it comes up as a cover for the bars I have. https://www.volvopartswebstore.com/prod ... 04744.html
9204754 and 9204755 are the part numbers for the front and rear bars, respectively.
Whomever put them on the older model may have gotten them from a P80 originally. Those should definitely be the same racks.
I'll double check the length of the ones I have to be sure. Thanks again!
Do P80 Roof Load Bars Fit P2?
- Has thanked: 316 times
- Been thanked: 531 times
Nope, those are definitely the same ones. Mine definitely have a curve.
Just measured them, the longer one is 43 inches end to end and the shorter one is 41. Extended they are 46 and 44 respectively.
- 1733 Views
Last post by bmdubya1198
- 1731 Views
Last post by adryan
- 702 Views
Last post by crlande
- 8372 Views
- 1132 Views
Last post by packetfire
