s70 replacement headlight assembly question
kumulipo
- Year and Model: 1999 S70
- Has thanked: 7 times
I have a 1999 n/a S70 that needs to see down the road at night. I've replaced the original headlight nacelles with better ones from the wrecking yard, but they still suffer from a degraded reflector. I tried a TYC replacement, but it just wouldn't throw a decent beam pattern, so I returned it. Was this one defective or is that the norm? I shudder to price a pair from the Volvo dealer. Any suggestions? Thanks.
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
MDK here. Something you may not be aware of. Those year cars and wagons come prewired for fog lights. All you have to do is find an xc70 pull the headlight module from under the hood... it's under where the fuses are. Pull the fog lights themselves... you'll need the switch in the dashboard that turns them on and lastly the jumper relay that's under the dashboard under the steering wheel. It may seem like a lot but once your done it really helps at night. I've done this many times. Oh yeah... don't forget to get the grill covers for the fog lights....MDK rolling on
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
IMHO, the fog lights in these cars are essentially pointless.
They only work with lowbeams and have no reach to speak of.
Two popular headlight upgrades for distance are buckets with
reflectors that are still shiny and E-code lenses, or even better,
the “jewel” type headlights from 2003 and 2004 C series P80’s.
Spend a little time searching the forum for previous posts
on the topic to nail down specifics. Both options also benefit
greatly with higher output lamps.
Another favorite is getting a set of jewels and modifying
them with HID projectors. Again, there are plenty of
write ups here on this site, SwedeSpeed and VolvoSpeed.
Fear Not - You are not alone in this quest!
- Has thanked: 1611 times
- Been thanked: 4075 times
Strongly disagree. They let oncoming traffic know a d*head is passing.IMHO, the fog lights in these cars are essentially pointless.
- BEJinFbk
I think about the only time that I use the fog lights,abscate wrote: 03 Jul 2018, 08:27Strongly disagree. They let oncoming traffic know a d*head is passing.IMHO, the fog lights in these cars are essentially pointless.
( front and rear ), is when there’s a lot of snow getting
kicked up, or in that awesome “ice” fog we. get around
here, so yeah -Good for being seen!
Personally, I cheaped out. I was lucky enough to have
nice shiny reflectors, but I’ve always been an E-code
guy, so I swapped to that pattern, added SilverStars
and now I just lust over OEM jewels...
- BEJinFbk
I'm curious about how they're holding up for you.blkbeauty wrote: 03 Jul 2018, 21:35 I purchased DEPO Jewel headlight assemblies for 2003-2004 C70 from Amazon. Direct fit, all glass, wonderful!
How long have you had them?
Anything special for lamps?
And to the OP - Whatever you do,
don't skimp on lens protection.
3M Xpel is worth every penny!
- RickHaleParker
- Been thanked: 980 times
The point of Fog lights is to illuminate the road. So that you can see where the road is and avoid running off the road.
Fog lights are so the driver can see the road not see down the road. It does make sense that they only work with Low beams. High beams should never be turned on in Fog because Fog is reflective. If High beams are turned on in fog, light off the fog reflects back at the driver, reducing the driver's ability to see.
Active
Past
Past
- BEJinFbk
My response was to MDK, who suggested fogs for increased longRickHaleParker wrote: 04 Jul 2018, 18:14 IMHO, the fog lights in these cars are essentially pointless.
distance lighting. I believe that I was making the same essential
points about fog lights that you are above, with more of an aim to
move it along and provide some solutions to the OP’s original issue.
I agree that fog lights are not designed to be used as driving lights
and concur that it’s practical and quite convenient that most OEM
fogs only operate in low beam mode.
My opinion that the fog lights in these cars are essentially pointless
stands, and can be easily supported with short drive through the soup
with decent, correctly aimed after-market units. The fogs provided by
Volvo for the cars under discussion ( again, just my opinion ) are simply
not adequate for their appointed task.
However, as expressed by myself and others, they’re still helpful for
making yourself a little more evident to other drivers when the
weather reduces visibility. As long as they aren’t texting...
- MDK
MDK here... I just thought it was cool that this particular manufacturer had the presence of mind to pre-wire these cars for fog lights. I went to the junk yard and found a wagon that someone had put brand new factory headlights in before junking it. I bought them for 20$ a piece instead of 249$ a side. So..., you know..... rolling on
- 12 Replies
- 2138 Views
Last post by bmdubya1198
- 795 Views
Last post by rguzz
- 735 Views
Last post by vtl
- 442 Views
Last post by VolvoNinja
- 806 Views
Last post by vtl
