Volvo 850 Jack Point Failure
henrysin44
Year and Model: 1994 Volvo 855 Turbo
Has thanked: 2 times
Been thanked: 3 times
Post by henrysin44 »
Over the weekend I changed my driver side CV Axle, however when I went to jack the car up the jack went right through the floor! Didn't hit anything important though.
Is this a first? Not even a little rust in sight and after inspecting it only 2 tac welds held it to the frame (the failure point), seems like a terrible design!
Jack point
Jack point
I currently have a heavy layer of gorilla tape covering the hole to prevent rust and fumes entering the cabin, either sometime this week or next im taking out the driver seat, pulling the carpet back and welding the hole shut. I have a sheet of some tough steel, primer, and under coat.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Are they robotic welds or where they done by a human?
Robotic would indicate design defect. Human would indicate somebody cut corners.
From the picture it looks like it has been abused.
Active
Past
henrysin44
RickHaleParker wrote: 02 Jul 2018, 03:27 Are they robotic welds or where they done by a human?
Looked robotic, almost perfectly circular tac welds.
I looked at the other jack point and its starting to seperate from the frame and missing the dowel. Ever sense i bought the car the jack points looked abit beaten so ive avoided using them to jack the car up when possible. Subframe is a better spot to raise the car anyway.
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
RickHaleParker
Could it be that a previous owner used the wrong jack and jacked up the jack points ...?
Active
Past
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
The whole emergency jack system is a bad design. My volvo jack failed the other day while inspecting my seized caliper. Fortunately it seems the jack took the brunt of the damage and not my precious volvo.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
WhatAmIDoing wrote: 02 Jul 2018, 06:53 The whole emergency jack system is a bad design. My volvo jack failed the other day while inspecting my seized caliper. Fortunately it seems the jack took the brunt of the damage and not my precious volvo.
To be fair, the Volvo jack should only be used as a last ditch effort not for standard maintenance stuff.
WhatAmIDoing
polskamafia mjl wrote: 03 Jul 2018, 09:57
I bought jacks and stands for standard maintenance, but I mistakenly thought it was a good idea to lend them to a friend (haven't seen 'em in a month). The Volvo jack always sketched me out whenever I had to use it.
Has thanked: 311 times
Been thanked: 817 times
Tha's a bummer, sorry to see.
henrysin44 wrote: 02 Jul 2018, 04:21 ... Subframe is a better spot to raise the car anyway.
+10,000, good call. I can only recall using the factory jack or jack points one time, changing a tire on the side of the highway. I always lift it from the subframe, always from the center lifting both sides, always drop in two jackstands. In the rear I place a board across the weld point of the tow loop and raise up both sides, then drop in two jackstands before doing anything.
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I asked the local indy shop to put my car up on the lift for a complete inspection of needed repairs. The tech put the lift arm pads under the frame rails. When I questioned that, he pointed to the jack point and noted that it's attached to the frame rail, the strongest part of the car's platform. No harm was done. I always place the jack pad under the gusset plate that mounts the subframe to the body rail, or the rear end link capture plate. I always use heavy wood blocking (10 x 10's, 3 x 6's) to support the car before I get a wheel off or otherwise underneath it. No jack stands for me. In wood we trust.
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
I see a rusted jack point. Check the other side.
