98 Volvo S70 GLT A/C Compressor fault. Replaced AC switch 30767231, 8628563 Topic is solved
vlr7
Year and Model: 850T-5R, V70-s
Post by vlr7 »
1/2 and 2/3. 2 being signal, 1 (-), 3 (+)
Been thanked: 4068 times
1-2 40 kOhm
2-3 40 MOhm
Measured at sensor on my 99
vlr7
Post by vlr7 »
I got also one sensor from 99 XC. And i tested them, pin 2 (the signal out was 0,9-1,5V with working pump), it came out it wasnt the bad sensor. It was engine ecu. Luckily i had another ecu, and it is working. Fol-FCR is showing correct values now. But climate pump still switches off after ~5min, so i guess its the clutch that has too large gap and gets overheated. Will sort this out and keep you guys informed.
