My 1994 850 cut out going over a speed bump and now won’t start. The serpentine belt was half shredded with pieces wrapped around pulleys. My tensioner is not in line with the belt I just realized after replacing the belt but all pulleys spin freely so I don’t see this keeping the car from starting, but this is causing a new line of wear exactly where the other belt shredded. (3/4 of the belt width was still there) It cranks, but no start. I have spark and fuel. It attempted a start and blew black smoke from somewhere under the hood and died again (this start up was noisy and lasted less than 5 seconds) I have now also noticed, may or may not be affiliated, but there is a clear oily liquid now soaking into the driver side floor. It’s coming from the area of the heater core but it’s not the antifreeze/burnt water smell it gave off before replacing that a year ago. I noticed a clear odorless oil drip on my driveway, coming from passenger side a couple days before the belt incident, but that’s on the opposite side of the car and again I don’t know if it’s affiliated with the driver side leak or the engine not starting but I am giving all information noticed. This leak could possibly be right under pulleys or passenger side brakes.
The engine turning also seems sluggish and noisy when trying to start the car.
If any other info is needed, please advise.
94 850 manual wagon, cranks no start after shredding serpentine belt
Tomasdvolvo
- Year and Model: 1994 850
- Has thanked: 1505 times
- Been thanked: 3818 times
I suspect the tensioner is the wrong part
The SERP belt won’t prevent starting so you should follow the nostart thread
- June
- Has thanked: 523 times
- Been thanked: 261 times
Could the clear oil in the driver's side floor be break fluid leaking through the booster? When the belt wrapped around the pulleys could it have pressed on the timing cover causing the timing belt to skip a tooth or so? June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Tomasdvolvo
As far as the tensioner and belt that is definitely our issue for a chewed belt, but we can’t figure out the no start. I’ll look for that thread, thanks.
Tomasdvolvo
Hi June, we will check on the break fluid from the booster. As far as the timing belt, the cover looks fine and we also have tested the belt and timing and it appears ok. Marks are lining up 100%.
- June
Tomasdvolvo wrote: ↑04 Jul 2018, 17:45Hi June, we will check on the break fluid from the booster. As far as the timing belt, the cover looks fine and we also have tested the belt and timing and it appears ok. Marks are lining up 100%.
Thank God the timing belt is fine! Could there be some pieces of the belt jamming something out of site like behind the balancer? Is there a sensor or wire that could have been damaged or unplugged slightly? I sure hope you figure it out. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
All clear oily stuff is coolant.
The car will start without the serpentine belt, so you can take that off and have that removed from the equation.
Tomasdvolvo
here is a video of us trying to start the vehicle. It does occasionally backfire while attempting to start but didn’t in this particular video.
- 21 Replies
- 10890 Views
Last post by bmdubya1198
- 12 Replies
- 2000 Views
Last post by Faust
