Coolant -- Need Brand Recommendation
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
2006 V70 base, auto. Timing belt change tomorrow. Water pump will be changed as well. Accordingly, coolant gets drained. I won't be able to pick up Volvo coolant between now and tomorrow morning.
Any recommendation on preferred coolant? My mechanic will use universal/green if I don't supply my own coolant. I was thinking along the lines of G5. What's best alternative to Volvo brand coolant?
Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1611 times
Been thanked: 4074 times
Pentosin blue stuff is what I use.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I'd rather fill with the Prestone Radiator Flush+Cleaner plus a few gallons of distilled water and drive gently for a few days, then rinse with distilled water, then fill with Volvo coolant ($25) + dw. It is a good start not knowing what was in there before. I just did this because I didn't get enough cabin heat in winter, now it blows at 180F
E Showell
Post by E Showell »
Pretty sure I've got Volvo coolant in there now. Have to go with what's available at the commercial auto parts stores in the near term -- probably opting for G5. I don't want to put new coolant in then replace in a few weeks' time with Volvo coolant. I hate dealing with coolant. It's a feel thing. I dislike the greasy/slippery aspect of it. Plus disposing of used coolant is a bit of a hassle.
'95 855 auto (sold)
If you have sewers most muni allow disposal of personal amounts down the drain. Check with your local muni for their regs. Glycol breaks down in a week or two.
Nitrile gloves are the first thing I put on when I mechanic , nowadays.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
abscate wrote: 12 Jul 2018, 04:30 If you have sewers most muni allow disposal of personal amounts down the drain.
Ooo..not here!
Yes on those gloves. Unless it's above 85 in the garage!
E Showell
Post by E Showell »
Valvoline HOAT was what was available. That's what I'll be using unless someone gives me a good reason not to between now and tomorrow morning.
'95 855 auto (sold)
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
My two cents: anything of decent quality will do fine as long as it's the only stuff in there.
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
You can plan a timing belt change and not have time to order a jug of Volvo coolant online?
