Can anyone give me symptoms of a bad fuel filter?
- Has thanked: 2861 times
- Been thanked: 1332 times
ETM will be hunting for idle, typically. Clogged fuel filter will be choking behavior, typically.
- Been thanked: 504 times
- Clogged Fuel Filter: car lethargic during acceleration.
- Bad Throttle Body: uneven rpm at idle.
I cleaned the TB in my 2005 XC90 and posted the DIY photos in XC90 forum. Very very simple thing to do, no need to remove the Intake Manifold.
Reason: hyperlink added
jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
Hmm ok cool. My car has plenty of power on acceleration. But hesitates when starting off from a stop. And when driving. Like ill let off throttle to coast and when i give it throttle again it will hesitate. And the idle is rough. I was thinkin it might be fuel filter.
- Been thanked: 4071 times
Tons of causes spanning ignition and fuel
How old are plugs and ignition coils?
Check induction path by removing fat hoses, check for splits, reclamp tightly.
Fuel problems unlikely on P2 models, especially if things work well under load
Codes under rough running are unreliable, so don’t treat them as a Gospel.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
I believe MAP sensors are not cheap things so do what everybody says to do all the time.
And that is to cross the T's and dot the I's with all the cheap stuff first. Just change the fuel filter and as abscate suggested, make sure the plugs aren't "old and closed". Checking the large air handling hoses is "always" a first thing to do.
Add a 20 oz. bottle of Techron concentrate before a stint of local driving.
I wasn't aware that the coils aged. I know they can crack and go to ground prematurely. Removal and CAREFUL examination is in order. Look for cracks and carbon tracks.
Have you even looked at your ETM? You do have the old style ETM and it may have worn out it's mylar strip.
How many miles are on your '01 XC-70? Does the air filter have 80,000 miles on it...easy stuff does get overlooked.
jking4020
Well...fuel filter is replaced. Vac lines seem good. Large air lines look good. Plugs are new. Coils look ok. Timing belt is new. Next to new air filters. Pcv is cleaned out. Only has 196k miles. So young for an 02. Gonna replace fuel rail in the future. The project moves on. Still hesitates n idles rough. Oh well. Why do I love these cars?
- 4382 Views
Last post by gnalan
- 1152 Views
- 12 Replies
- 3062 Views
Last post by erikv11
- 597 Views
Last post by yabadabadoo1026
- 709 Views
Last post by MAC99
