1998 S70 T5 cylinder head interchange
Bigssherod
Year and Model: 1998 S70 T5
Post by Bigssherod »
Hello I am new to this form I have a 1998 Volvo S70 T5 with a 2.3 Turbo my head is Warped over 12,000 I am looking for a cylinder head and I was wondering what year and model of car will interchange with my 2.3 Turbo
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
The core charge on these heads is ~$400. Are you planning to swamp it with a pick-in-pull? With a pick-in-pull you would need to check the head for flatness, so there no getting around the $100 for a precision straight edge. If you got a lot of elbow grease and willing to work like an old school man. It is possible to true an aluminum head under the shade tree with simple homemade tools and a precision straight edge. Wet and dry sandpaper will cut aluminum, cut and true the head with wet and dry sandpaper planes.
The head is Volvo part number 8111178. Part number 5003932 with valves included.
Volvo 850 2.3l 5 cylinder Fuel Injected Turbo 1994, 1995, 1996, 1997
Volvo 850 2.3l 5 cylinder Turbo 1995, 1996, 1997
Volvo 850 2.5l 5 cylinder Fuel Injected 1993, 1994, 1995, 1996, 1997
Volvo 850 2.5l 5 cylinder Turbo 1997
Volvo C70 2.3l 5 cylinder Turbo Convertible 1998
Volvo C70 2.3l 5 cylinder Turbo Coupe 1998
Volvo C70 2.5l 5 cylinder Turbo Convertible 1998
Volvo C70 2.5l 5 cylinder Turbo Coupe 1998
Volvo S70 2.3l 5 cylinder Turbo 1998
Volvo S70 2.5l 5 cylinder Fuel Injected 1998
Volvo S70 2.5l 5 cylinder Turbo 1998
Volvo V70 2.3l 5 cylinder Turbo 1998
Volvo V70 2.5l 5 cylinder Fuel Injected 1998
Volvo V70 2.5l 5 cylinder Turbo 1998
Volvo V70 XC 2.5l 5 cylinder Turbo 1998
Bigssherod
Wow thank you so much for your help
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
One caution regarding the part number and applications. If you get a head from a non-turbo car, swap the exhaust valves from your turbo head. They are sodium filled in order to deal with the heat from the turbo.
Current Volvos:
Has thanked: 292 times
Been thanked: 765 times
Any 94-98 turbo engine, from an 850 or x70.
As per FLXC90, a non-turbo head is not a direct swap. Note that people have done the direct swap, but I wouldn't unless you swap in the exhaust valves from a turbo head. HPT to LPT doesn't matter, they use the same valves.
I would look for for a turbo head, it's pretty simple what works and they should be pretty common in Oregon. Why move over 10 exhaust valves if you don't need to.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
