Diary of a 17 y/o with an 850
Didn't the pictures how OBD inside the cabin??
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yes...but again....a '95 came with both OBDII in the cabin and still with OBDI under the hood.
It was a transitional year from OBD I to OBDII.
'96 and after didn't had diagnistic ports under the hood anymore.
Also Motronic 4.3 is used only in turbo engines.
Motronic 4.4 didn't exist untill late '96 and in all '97 na models.
It can only be LH 3.2 Jetronic with OBDI ports in '95.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
If the fan is running as soon as you turn the engine on, it’s either a bad temp sensor or bad head gasket.
Before you start spending money on small things fix the big things.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- misha
In this case...it can be anything...wrong wiring paired with wrong management...etc.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- shihabafi
- Year and Model: 1995 850 Wagon
- Has thanked: 50 times
- Been thanked: 8 times
10th digit of my VIN is S.
Also, Check Engine Light threw an "Engine Coolant Temperature Sensor 1 Circuit Low" -this is the thermostat, right?
Is now a good time to mention that when we pulled out a Camshaft Position Sensor (for my most recent job), we pulled one out of a non-turbo and it started smoking up. So we matched up the part numbers and noticed they weren't the same. So we went back to the junkyard to find one that matched our part, and lo and behold, it belonged to a turbo-ed engine. We were also confused, but hey, the numbers matched.
couldn't find the second place with the etched on numbers, but I did find this:
And this under the hood:
- RickHaleParker
- Been thanked: 978 times
Vin Position 10: S = 1995
Active
Past
Past
OBD II certified.
- RickHaleParker
The B5254S are equipped with Bosch LH-3.2/EZ-129K engine management for model years 1995 and 1996.
1997 and on are equipped with Bosch Motronic 4.4 engine management.
Active
Past
Past
- RickHaleParker
That is just the VIN coding sheet. It does not mean a YV1Lx553xSx000000 was ever built.
Shihab, post the first eleven positions of the VIN number.
Active
Past
Past
- 46 Replies
- 7971 Views
- 9 Replies
- 5028 Views
Last post by vtl
- 4700 Views
Last post by tryingbe
- 668 Views
Last post by shaker_chi
- 876 Views
Last post by misha
