All,
Looking ahead to replacing my rear shocks before the snow flies here in New England and wondering if the collective brain had any opinions on Bilstein Tourings vs KYB Gas-A-Just. Looking for a firm (but not harsh?) ride.
Any thoughts?
V70 Rear Shocks - Bilstein Touring vs KYB Gas-A-Just
a3inverter
- Year and Model: 2006 V70
- Been thanked: 9 times
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Touring shocks are OEM. I went the Bilstein HD route and loved them. They weren't harsh.
KYB Gas-A-Just aren't adjustable. I wouldn't buy 'em for using that cutesy name.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Sachs are oem. But we get a different flavour over here compared to what you seem to get. Silver labels and no "Super Touring" name. Bilsteins should be perfectly fine as well though. And KYB is a big manufacturer, they'll probably be fine as well. Anything is better than old shot shocks but cheap ones might need replacing sooner..Georgeandkira wrote: 17 Jul 2018, 11:51 Touring shocks are OEM. I went the Bilstein HD route and loved them. They weren't harsh.
zanzabar
- Year and Model: '07 V70, '84 245
- Been thanked: 4 times
I also have Bilstein TC and like them a lot. Very firm, but that may be partly because of the Eibach lowering springs I paired with them. Not too harsh, but you definitely get a jolt from significant road bumps. I can only assume Bilstein HD would be harsher, and I have not had any experience with KYB Gas-a-just, just the regular KYB ones which seem a bit less stiff than Bilstein TC.
Just stay away from Gabriel (they are garbage)!
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
a3inverter
Agree. Not looking to cheap out. IIRC, the Gas-a-Justs are the mid-range of the KYB line. Agreed on Gabriel - put a set of those on my wife's VW Fox twenty years ago. That car and those shocks deserved each other
- Has thanked: 2857 times
- Been thanked: 1332 times
Was this on your V70 R?Archer wrote: 17 Jul 2018, 11:02 Just did Bilstein Touring, front & rear, along with Ipd sway bars...very pleased, economical...did not feel it necessary to install the HD's.
Georgeandkira
To be clear: I also installed a full set of Sachs Super Touring on a V70 and essentially felt little difference. That was notable because both front struts were completely blown. No resistance and oozing fluid.
The HD (B6) Bilsteins hit the target and I believe if you install them on the rears, as you stated, you COULDN'T POSSIBLY be harshed-out. They'll be at the tail end of a long, 3,700 pound car. Go for the yellow!
Also, the manufacturers accommodate lowering schemes with different shocks. I don't think a reasonable comparison is possible. In the case of lowering a V70 Bilstein's B8 is called for.
a3inverter
My V70 is low enough for my middle-aged self already
- 1454 Views
Last post by shiloh51933
- 936 Views
Last post by coodoo99
- 13 Replies
- 5031 Views
Last post by v-45magna
- 2064 Views
Last post by MoVolvos
- 1080 Views
Last post by velorider
