Unidentified problem.limp mode.Dtsc
Szava
Year and Model: 2008 Volvo V50
Post by Szava »
Hello,can someoane please help me.I have some issue regarding to my volvo v50 2008 model.it all started whit a message that the car has reduced engine power.after that it changed to anti skid problem.the car sometimes gets into limp mode.After restart the message dissapears.after a few miles it does it again.I have tried a lot of service places and they can not find the problem.The error codes are 0101 and A030.If you have any tips please help me i have already spent a lot of money for changing stuff and it still is the same.I have changed the alternatir the turbo the ecu module,egr sensor and the vireing was checked also.Nobody can find the problem.Thank you.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
The error codes 0101 and A030 are incomplete.
I suggest you invest $80.00 in a VIDA DiCE clone so you can get good information. Then work from good information rather then guess.
Active
Past
Szava
Post by Szava »
Thanks for the tip.Can you suggest what type to get for a 2008 model?Can a newer model ex:2014d work as well?
RickHaleParker
On the DiCE hardware clone look for one that is full chip and J2534.
Don't use the software that comes with it, Use Vida 2014D_RePack and the 2099 patch instead.
Active
Past
