Reattach inner door panels
bw77
Year and Model: 99 S70GLT
Post by bw77 »
Need to reattach the inner door panels on my 99 S70.
What would be a good adhesive? Any of these?
GE Silicone Iron Grip
DAP contact cement
3M 77
3M molding tape
Thanks.
raivis_rsn
Year and Model: V70 1999 TDI
Been thanked: 7 times
Post by raivis_rsn »
Double sided tape works just fine. I went that way with my V70.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I think I used plain old GE bathroom caulk that came from Home Depot.
bw77
Post by bw77 »
I tried tape and caulk.
The tape I found nearly impossible to remove the red strip, on youtube it
looked trivially simple, not for me. The caulk did not hold even though I held it
down with weight overnight. So I said screw it, and 6 screws later it was back together.
I guess I have little patience for adhesive/trim work.
And the original problem I was trying to fix turns out to be a Volvo feature.
I have owned this car from new and had never heard of it before.
Each door actuator has a thermal protection feature, so in hot weather, or
if someone were to lock and unlock the doors repeatedly, they stop working.
I couldn't understand why the door locks worked a few times then quit. I
thought heat related, maybe a circuit board.
A learning experience all around.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
I think I used hot glue.
You could also use Sonneborne NP-1. Problem is you could never remove them again.
M1 10W-30 HM
