Volvo Brake Line
trumpetted
Year and Model: 2001 S80
Post by trumpetted »
Volvo s80
2001
VIN # YV1TS94D611176016
I am looking for Volvo part number 9140857 brake pipe/brake line for the front passenger side of my 2001 Volvo s80. I realize it has been discontinued and is no longer being produced. I am sending emails all over the world trying to find this part new or used. Do you have any idea where I can find this brake line? A wonderful old 235,000 mile Volvo s80 (original owner) may go to the wrecking yard if I cannot locate this part. :cry: Thanks!!!
Ted Zalkind
Penn Valley, CA USA
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
There is a 1999, 2002 and a 2003 S80 at the Pick-n-Pull in Antelope, CA. $6.49 for a brake line or hose.
8640 Antelope North Road
Antelope, CA 95843 US
Phone 1: 916-721-4040
Phone 2: 800-442-5865
Fax: 91‍6-725-0321
Hours:
Mon-Fri 9:00 am - 6:00 pm
Sat-Sun 8:00 am - 6:00 pm
(Yard closes 30 minutes prior to store closing)
Active
Past
trumpetted
Thanks so much! I live about 6 hours from Antelope but I will see what I can do.
RickHaleParker
You signed the message Penn Valley, CA that is why I look at the Antelope, CA yard (50 miles).
Use the Pick-n-Pull link there maybe something closer to where you really are.
Active
Past
trumpetted
I did not realize at first where the Antelope yard was located. I went to the yard today and pulled a perfect condition line out of a 2003 s80. The only difference is the fitting on the distribution side is larger on the "99-01 than on the following years. The car is now at a local shop and they said they can make the alteration to the line without any issue. I started off replacing all of the rubber brake lines as they were cracked and had several soft spots. The car is mostly a CA car but it did spend some years in a snowy climate. The rubber lines were very difficult to separate from the hard lines. I succeeded on the first three but that drivers side front is where I damaged the hard line. The shop is going to install the new line and bleed the brakes. Thanks so much for your suggestion! You are helping keep my old Volvo on the road!!!
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
trumpetted wrote: 25 Jul 2018, 22:44 I did not realize at first where the Antelope yard was located. I went to the yard today and pulled a perfect condition line out of a 2003 s80. The only difference is the fitting on the distribution side is larger on the "99-01 than on the following years. The car is now at a local shop and they said they can make the alteration to the line without any issue. I started off replacing all of the rubber brake lines as they were cracked and had several soft spots. The car is mostly a CA car but it did spend some years in a snowy climate. The rubber lines were very difficult to separate from the hard lines. I succeeded on the first three but that drivers side front is where I damaged the hard line. The shop is going to install the new line and bleed the brakes. Thanks so much for your suggestion! You are helping keep my old Volvo on the road!!!
I am so glad you got what you needed! It made me sick the other day to read it might be junked over a brake line. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
If you're still looking for the brake line, try:
http://www.autodisassemblyvolvo.com/parts.html
(More likely to have used)
http://voluparts.com/
(More likely to have new)
Either place can ship to you.
Has thanked: 1611 times
Been thanked: 4075 times
You can make up hard lines using a flare tool and the line you buy at a FLAPS.
One of the reasons MFG drop these from the parts supply chain is that they are easily made up.
a NAPA store can do this for you. Overcome the initial 'legal won't let us' objection with beer.
