I need to short belt the Serpentine until I can get to a defective A/C clutch or pulley bearing. Has anybody worked out a short belt that will do?
Clutch is dragging and rubbing when the coil is disengaged. Alignment between the pulley and clutch is not true.
1997 S90/960 2.9L Serpentine Short belt. Topic is solved
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
- RickHaleParker
That plan is shot to hell. Pulled the Clutch hub hoping it was just the bearing. Bearing rock solid. I can find clutch hubs but not the pulley. This is the first time I had a pulley do this ..... Pulley hub separation.
BTW: Three M6 bolts is all you need to push a stuck Clutch hub off. Screw the three M6 bolts into the three holes and tighten then down, they will push the hub off. No need to make, rent or buy a puller when a dirt cheap pusher will do. You can also use the three M6 bolts in lieu of a three pin spanner. Two specialty tools replaced buy three cheap bolts.
Front
Back
Front
Back
Active
Past
Past
- RickHaleParker
Figure out a short belt option for White block RN engines (4, 5 & 6 cylinder) , Volvo part number 9146844.
Will keep you rolling after a A/C compressor lockup .... etcetera.
Cross reference:
BOSCH 1987947887
BREMBO 6PK1256
CONTITECH 6PK1256
FAI AutoParts 6PK1270
GATES 6PK1255
GATES 6PK1263
GOODYEAR 6PK1250G
LEMFORDER 17185 01
MAGNETI MARELLI 331622002320
MAPCO 261255
MEYLE 050 006 1255
OPTIBELT 6 PK 1255
SKF VKMV6PK1253
SWAG 55928937
I'm not sure if it will work for the RNC engines.
Cross reference:
BOSCH 1987947887
BREMBO 6PK1256
CONTITECH 6PK1256
GATES 6PK1255
GATES 6PK1263
GOODYEAR 6PK1250G
LEMFORDER 17185 01
MAPCO 261255
MEYLE 050 006 1255
OPTIBELT 6 PK 1255
SKF VKMV6PK1253
SWAG 55928937
Active
Past
Past
- RickHaleParker
Confirmed: I got the Duralast equivalent from Autozone. Autozone/Duralast stock number 495K6, European standard 6PK1255.
Use the official Volvo short belt routeing. It is a tight fit, you will need to slip the belt on as somebody bumps the starter.
Active
Past
Past
- Been thanked: 4068 times
Note that it reverses the direction of alternators rotation, which won’t affect electrical operation, but if you have a free wheeling pulley, it will no longer charge. I believe free wheeling pulleyscame standard in 1999
- RickHaleParker
The alternator does not reverse direction.
On the left the belt is moving left to right at the alternator, the belt runs over the top of the alternator pulley spinning the alternator clockwise.
On the right the belt is moving right to left at the alternator, the belt runs under the bottom of the alternator pulley spinning the alternator clockwise.
Active
Past
Past
- RickHaleParker
Notes for format 6PKXXX
6 = number of ribs.
PK = Profile, Rib spacing 3.6mm, Belt thickness 4.6mm.
XXXX = Belt length in mm.
6 = number of ribs.
Active
Past
Past
- 20 Replies
- 17515 Views
Last post by Hurtfeelings
- 1975 Views
Last post by RickHaleParker
- 14 Replies
- 3136 Views
- 761 Views
- 437 Views
