Swapping manual to an auto- You read that right! Topic is solved
Kara503
Year and Model: 1996 850 Plat R-Swap
Has thanked: 17 times
Been thanked: 5 times
Post by Kara503 »
It finally happened!! For only $500, I sourced a 1997 N/A 855 with an m56! I can't wait to start the swap on my platinum! 8)
However, the donor car is in great shape. The engine runs strong, the body and interior are great other than some pass. side body damage, and I am in need of a backup car. It is also a red 855 which I have ALWAYS wanted.
What do I need to take into consideration if I am going to swap the auto trans from my Platinum into the red car? Wiring harness swap? Can I just cut part of a harness out of a junkyard car and do some splicing? Will I run into problems because the auto is going from a turbo car into an NA car? Anything else I am forgetting? Any insight is helpful :)
96 855 Platinum- Elsa
98 V70R- Goose
06 S40 NA- Hilda
02 VW Jetta TDI wagon- Dizzy
sventastic
Year and Model: 1996 854R
Been thanked: 6 times
Post by sventastic »
The N/A car will get even slower because the turbo auto transmission has longer gear ratios :P
I'm unfortunately not of much help on wiring. Onething to check would be whether they use the same type of ECU - should both be M4.3?
1996 854R | M56H | 16T | 274k | BC, Canada
Kara503
Post by Kara503 »
sventastic wrote: 27 Jul 2018, 14:27 The N/A car will get even slower because the turbo auto transmission has longer gear ratios :P
I'm okay with the gear ratios. It would be a backup daily driver and my utility wagon, so slow/ better mpg is better :)
Good call on the ECU control! A quick google search reveals that 1996 and 1997 (The years for the cars) could be either 4.3 or 4.4. Looks like I need to find out.
98 V70R- Goose
06 S40 NA- Hilda
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
I’m sure that I’m not the the only one thinking this,
but have you considered just leaving the $500 car
alone and and continuing your quest for a tranny?
I’m just sayin’ - If it ain’t broke...
Kara503
Post by Kara503 »
BEJinFbk wrote: 27 Jul 2018, 20:15 I’m sure that I’m not the the only one thinking this,
I haven't because I already bought the car but I understand what you are getting at. That's why I want to put an automatic transmission back into it so it can be used again instead of scrapping another good 850. This is the best way for me to make sure I have all of the parts for my swap project on my platinum- I have been looking for almost a year now and the standing price on most of these transmissions is around $700, and that's without any supporting components (pedals, cables, shifter, etc) or the ability to road test it beforehand.
98 V70R- Goose
06 S40 NA- Hilda
Has thanked: 1505 times
Been thanked: 3818 times
You can chisel a weasel down at least 50% on that price.
You can get an entire blown M56 car for $500, get all the parts you need and part the rest to make the M56/free
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Keep the 855 manual. You'll love it. Ask me how I know.
FireFox31
FireFox31 wrote: 30 Jul 2018, 19:15 Keep the 855 manual. You'll love it. Ask me how I know.
That’s excellent
+5000 points
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
Firefox, mind if I use that photo for the July MVS newsletter?
Also -> Amazon link
matthew1 wrote: 31 Jul 2018, 11:02 Firefox, mind if I use that photo for the July MVS newsletter?
Shift free or die...
