'08 Volvo V70 - Very loud high-pitched whine
lumpyboris
Year and Model: 2008 Volvo V70
Post by lumpyboris »
On a road trip, and had (non-turbo) car checked out day before I left -- everything was in good order, except for a couple random misfire codes that didn't seem too troubling so we left them.
Within the last 100 miles or so of my trip, the car started making this very loud high-pitched whine, which sounded like it was coming from the driver's side of the car. The sound was continuous when idling, parked, coasting, or slowing down; the sound went away when I was actively giving the car gas. The whine was not connected to AC/radio/anything like that. The whine was not connected to braking/the brakes. Nothing else about the engine sounds off, the car feels like it is running smoothly and normally. After driving for about 95 out of the 100 miles, the "check engine" light came on. Any ideas?
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Constant pitch and volume or does it change with engine revs?
lumpyboris
Hi Rattnalle,
Constant pitch and volume. Like the tone you hear in your ears after going to a loud concert or something.
Rattnalle
Post by Rattnalle »
Interesting. That would seem to rule out both vacuum lines and anything connected to the engine.
If the sound is there at idle you should probably try pinpointing it a bit more.
Georgeandkira
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
Have you had the code read? Do you have a reader.
Does the '08 have a motor driven air pump to "fan the fire" in the cat so it warms up faster?
It's supposed to turn off after a while but could be broken.
Does the fuel system have a valve to return fuel to the tank?
Have you lifted the hood and tried to zero in on it? Get a tube to focus your hearing.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
lumpyboris wrote: 05 Aug 2018, 09:43 the sound went away when I was actively giving the car gas
How many miles on this puppy? I would bet a few $ on the PCV box, if the noise goes away as you pull the dipstick or undo a little the engine oil cap. If that seems to be the issue, I would drive the car unless removing the dipstick, or some engine seals may blow out (by the way, also check the engine oil level). Other things to do is to listen near the serpentine belt pulleys (with great care because of the rotating parts). As mentioned above may use a tube to listen www.youtube.com/watch?v=qVWY2fMzrpc
Also see if the noise stops when depressing the gas pedal
By the way, wasn't aware Volvo had the non turbo up to 2008 (or even 2009 perhaps?)
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Did you check the power steering fluid level?
Active
Past
lumpyboris
Yes, all fluids are good!
She's at just under 170 miles
thank you for all the suggestions! I will take it to my mechanic and toss these ideas around
oragex
Post by oragex »
Only thing, maybe if you get an estimate don't hesitate to update this, we may share suggestions about which part brands/fluids are better to use
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Does the whine stop if you loosen the oil filler cap?
