'99 S70 Base -- Rescue Candidate?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Pretty sure no CVVT.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 317 times
- Been thanked: 531 times
Exhaust VVT on an NA? Haven't heard that before.abscate wrote: 05 Aug 2018, 16:20 The !999 base I parted out had exhaust CVVT, so this one might be CVVT too.
I think I've seen only one or two 1999 NAs with VVT. Like I said, I think it was a mid year change.
Definitely worth a look see... maybe just keep the head on the car and swap the bottom end if it is VVT!
- E Showell
It is not VVT.
'95 855 auto (sold)
'95 855 auto (sold)
- Year and Model: Lots
- Been thanked: 128 times
VVT came in 2000 MY for NAs on intake. The intake port shape is vastly different on a 1998 model but the hole positioning is the same. The earlier ports are smaller and have that top ridge at 12 o clock. Some dremmelling of the head may be required for a better port match.
The 1998 and earlier heads also have the holes drilled to take the coil pack bolts. The biggest issue may be the cam sensor's pickup point. The earlier ones were on the exhaust. The bastards were on the intake. Some mods to the intake cam may be necessary to implement the later system but very doable.
- Has thanked: 1611 times
- Been thanked: 4075 times
The VVT from my parts 1999...is now on my 1999 T5
That parts 1999 would be a turbo.
It was definitely NA as I took the ETM without digging.
Best part of the RN NA engine!
Then it was a late 99 build probably September or past. Anyway you can't put a intake VVT on exhaust: different part number and it says INTAKE on the casting. If it works OK in the exhaust position it's not meant to.
The early builds had no VVT. Also your parts car would have had solid tappets, identifiable by the extra torx screws near the spark plug holes
If it had VVT it probably had solid lifters. I have a late '99/2000 NA head sitting in my shed right now with intake VVT and it has solid lifters.
- 94 Replies
- 10900 Views
Last post by bmdubya1198
- 10 Replies
- 1394 Views
- 509 Views
Last post by Clemens
- 2321 Views
Last post by leapdragon
- 14 Replies
- 2397 Views
