I have an oil leak. Definitely not cam seals, but apparently high on block. Mechanic says coming from valve cover area, but specific location not pinpointed.
Oil regularly changed around every 3 K by prior owner, passed glove test on PCV system pre-purchase. No evidence of rear main seal leak, no apparent sludging, no codes, no diminished performance issues. Oil pooling near front (under crank pulley) engine mount.
Any idea what's going on here?
2006 V70 Oil Leak-- High on Block near timing belt end
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Does it have cvvt cam solenoids, they can leak. I'd clean it up good and watch where it comes from.
Check spark plug wells.
Install new oil seal on the oil fill cap.
- E Showell
Not sure about the CVVT -- it is a 2006 base V70 non-turbo.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 311 times
- Been thanked: 817 times
Oil cap seal or PCV hose from the oil trap to the nipple on top of the cam cover. Both are common, oil cap more so, either one drains to the pass side once the oil pools up on top.
- E Showell
I'll change the oil filler cap seal, but I think it's leaking more than that.
'95 855 auto (sold)
'95 855 auto (sold)
- Been thanked: 4068 times
CVVT Intake if it is like 2005. There is a lot of oil flowing there, so that is where I would look.
- 12 Replies
- 6619 Views
Last post by adrian121
- 3352 Views
Last post by jumbicat
- 9 Replies
- 3269 Views
- 16 Replies
- 7179 Views
Last post by erikv11
- 1446 Views
Last post by Dan McBoost
