Maybe remove the center console, grind the remaining studs back to level and then drill 4 holes and run bolts from the inside out and a thin nut on the lower side by the muffler shield and then bolt it all back up with some large stainless washers between the nut and the plate to prevent further corrosion.
Volvo 850 strange "ash" cumulation around seat mount
- Has thanked: 1850 times
- Been thanked: 1712 times
Re: Volvo 850 strange "ash" cumulation around seat mount
JimBee
- Has thanked: 25 times
- Been thanked: 42 times
Ooof. Something like that first came to mind. With all the other little details and an axle boot to replace, well, time does slip away. Running it without the shield?
