2002 Volvo S40 Trunk wont open after battery change?
mountaincarjunkie
- Year and Model: 2002 Volvo S40 1.9T
Title. After I changed the battery the trunk wont open with the key or the faab. Any ides? The glove box isnt locked.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
The car battery or the fob battery?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
mountaincarjunkie
- alschnertz
The key doesn't actually open the trunk on my '01.
All the key does is manually enable or disable the push button latch.
As for why your fob isn't working, maybe it's coincidental. Maybe it'd be worth changing the fob battery.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
mountaincarjunkie
The key fob works with everything else. I'm assuming maybe the trunk switch or latch isn't working? When I use the fob I can hear the mechanism working just nothing happening.alschnertz wrote: 12 Aug 2018, 05:52 The key doesn't actually open the trunk on my '01.
- alschnertz
If you can hear the actuator cycling, maybe all that's wrong is a linkage fell off.
And if the actuator is cycling, I'd also think that the problem should be pretty obvious.
Pull the interior panel and have a look. You'll probably have to fold the rear seats and access it that way.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 1229 Views
Last post by oizdaman26
- 1139 Views
Last post by Vova585
- 18 Replies
- 20211 Views
- 275 Views
- 778 Views
Last post by aethera
