What is this hose connected to ?
Ajaga08
Year and Model: 1998 S70
Post by Ajaga08 »
Hi group. Im new here, this is my very first post
I have a 1998 Volvo S70. 2.4L Turbocharged and would like to know Where this mysterious hose supposed to be connected.
When I pulled in air from the hose, I discovered coolant fluid came out of it.
The hose is located on the passenger side from lower end of the engine close to the front fender(See Pictures).
I searched endlessly trying to find where it goes, all to no avail.
Can anyone help this poor guy ?
Image[/img]
Has thanked: 2203 times
Been thanked: 1852 times
Looks like the breather hose for the windshield washer bottle. It goes no where. Just prevents the bottle from causing a vacuum so is open to air as it should be. It should clip onto either the missing windshield washer filler tube that snaps into the semi-circular rind in the middle of the picture or onto a clip on the front of the casing for the ECU.
Ajaga08
Post by Ajaga08 »
Thank you. I was thinking its the cause of my P0172 Error Code. Thank you.
Has thanked: 311 times
Been thanked: 817 times
For the P0172, check the little black hose on the passenger side of the intake manifold, that connects to a metal nipple. The hose elbow may be crumbling or disconnected.
Ajaga08
Post by Ajaga08 »
Will do. Thanks
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Yep...it's breather hose for windshield washer reservoir.
It should have it's clip at the inner fender.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
Correct on washer breather hose. Can even see the metal clip in picture, look at yellow sticker and move left, follow the fender ridge down about two inches toward front of car.
Ajaga08
Post by Ajaga08 »
Thank you all. Much appreciated
Ajaga08
Post by Ajaga08 »
UPDATE: Had the hose tucked away by the fender but now I have P0455. I've read many posts suggesting replacent of Gas cap, Purge valve etc. All checked but Ill like to know If the Two Holes( pointed arrows in the picture) may also contribute to the error code P0455. The holes are located at the front of the Rear Tire on driver saide. Please enlighten.
Those 2 holes are just that and no more, The larger one should probably have a plastic bung in it.
P0455 is an emissions fault. You are looking for split or broken pipes in the emissions system. Yours being a 98 it is most likely the hoses on the carbon canister under the LH front fender just forward of the front tire.
