Hi,
I had an unusual problem yesterday. I drove my S40 for about 15 minutes without a problem. I stopped at a store. When I tried to leave, the car wouldn't crank. It had power as the lights and radio worked. The car wouldn't shift out of park either. Turning the car off and turning the key to the II position, the car would shift our of neutral. When I tried to start the car again (in park), it wouldn't cranked again, would refuse to shift out of park.
I repeated this several times without progress. I then locked/unlocked the car 5 times to turn off the immobilizer (if that was the issue) based upon advice from the internet. The car still wouldn't crank.
I then called my spouse to arrange for her to come get me. After 5 minutes on the phone, I tried to start the car and it started fine. I drove it home. Last night and this morning it starts fine.
Does anyone have any idea what might be the cause?
The car is a 2001 S40 LE with 200,000 miles. There are no other issues known with the car other than the P0015 camshaft code.
Thanks,
Tom
S40 Occasionally won't start, crank, but other times fine
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
I'd try two things.
First, you may want to remove and clean the battery cables and terminals.
Not sure if that would help, but it is something that is too often overlooked.
But I suspect your issue may be related to the PNP switch.
With the ENGINE OFF, try "rowing" the shifter from Park to Low 20-30 times - ENGINE OFF!
This may clean the contacts on the PNP switch and eliminate your issue.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
jefe
- Year and Model: 2001 Volvo V40
- Been thanked: 3 times
I thought PNP too but it's just a guess. Mine caused similar issues except that it would go into limp mode when it was flaring up.
The transmission would put out P0700 and/or P0705 codes as well.
"rowing" never worked for me, but I found an article somewhere about how to adjust the PNP switch. It only took 20 or so minutes and this worked several times for me over the course of a couple years before I eventually replaced the switch back in 2015. No issues since replacing.
- alschnertz
I've never had a reason to suspect a failed PNP switch either but have seen this remedy referenced on occasion.
At least it's something that can be done at no cost.
I know nothing of adjusting said PNP switch.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 1189 Views
Last post by dosbricks
- 992 Views
- 1857 Views
Last post by Davwatermk
- 648 Views
Last post by WhatAmIDoing
- 974 Views
Last post by FuddleyPJones
