Is your car ticking? Check the exhaust manifold gasket. Topic is solved
This topic is in the MVS Volvo Repair Database » Strange ticking sound . No codes. Could be the exhaust manifold.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Last autumn I had a weird ticking sound coming from the car. No other symptoms. Drove well. No codes. Eventually I put my hand behind the engine by chance and felt puffs of warm air.
Turned out one bolt from the manifold had fallen out and one of the gaskets was sitting slightly off. A new bolt later everything was fine.
So if you're hearing the below sound, check the exhaust.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Rattnalle, I promoted your account to MVS Contributor. You've helped Volvo owners so many times, and you haven't even been here one year. :shock:
Let me know if you want to keep your avatar as is, if you would like the standard MVS Contributor avatar, or if you would like a mash-up of the two.
Also -> Amazon link
