Beats me. I only use the normal ones myself.Durenol wrote: 21 Aug 2018, 14:05 That makes sense. I guess I should have clarified though that I mainly meant "for a joe sixpack working under his car", as I don't understand why you'd pick these over normal clamps that are cheaper, reusable, and don't require a special pair of pliers. Is it just for people who are obsessive about stock parts?
(OEM) Single Use hose clamp
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
- RickHaleParker
- Been thanked: 979 times
Oetiker clamps are designed so that they are spring loaded. That is they will "breathe" along with expansion and contraction. In my experiment with Zip ties I'm betting on the elasticity of nylon to do the same.
Active
Past
Past
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Durenol wrote: 21 Aug 2018, 13:15 As someone passing by this thread, what's the advantage of using these clamps vs the normal screw-tightening kind? These appear to be more expensive with no obvious benefit.
There's two types of screw (worm gear) clamps, the german ones are less prone to loosen with vibrations, while the hardware ones always loosen up. Imo, these may not stay tight enough, especially with temperature variation. Maybe the german one is safer but the problem here is playing with the rack - it's a bad and expensive job on this car.
the hardware store ones with straight holes
and the 'german' ones - what Volvo uses in the engine bay - with bent holes.
- RickHaleParker
Another reason, screw clamp dug in and ripped it.
Active
Past
Past
- Rattnalle
More accurate is probably that overtightening damages stuff. You can break pretty much anything using a screw on clamp if you tighten it enough.RickHaleParker wrote: 21 Aug 2018, 17:28 Another reason, screw clamp dug in and ripped it.IMAG0213.jpg
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
One (minor) thing I like about Oetiker clamps vs the worm screw type is that once they're tight they don't leave an excess "tail" hanging out to rake the back of your hand across.
Oetiker clamps are the only ones I’ve found that’s stop the power steering seep at the reservoir on either my P80 bastard and P2
- Rattnalle
I just added a quarter turn to the existing clamp and my leaks stoppedabscate wrote: 23 Aug 2018, 04:58 Oetiker clamps are the only ones I’ve found that’s stop the power steering seep at the reservoir on either my P80 bastard and P2
I’ll try that but a quarter turn in the clamp screw will work better.
Lashing out for getting me on the AC bearing......
- 707 Views
- 917 Views
Last post by polskamafia mjl
- 1568 Views
Last post by simonology101
- 1224 Views
Last post by mrbrian200
- 16 Replies
- 6839 Views
Last post by RickHaleParker
