Just had to say THANKS! For the tutorial. I'm a super self reliant single mom, I gotta be able to repair, replace, install any number of things from a washer & dryer to the pcv system on a volvo. Clear, direct tutorials (w/pix & a little humor!) Like yours help me do what I need to do when & how I need to do it, (by myself & NOW!)
Thanks & keep up the good work! (So I can too!)
Mcat1
P80 PCV System Repair on a Volvo 5-cylinder (-1998)
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 673 times
- Been thanked: 164 times
hy,
i have a question about this PCV : wouldn't be useful to install behind the engine block a bottle to catch oils steams before send it back to the engine ? Wouldn't solve the PCV issue for a while ?
Manov
Manov
- Has thanked: 311 times
- Been thanked: 817 times
It sounds like you are suggesting to install a catch can in addition to the existing PCV. This is a reasonable idea and has been done many times. Sometimes done well (some really good examples at Volvospeed), sometimes not so well.
Search "catch can" and your car model of choice for some examples, there have been some clever implementations.
shaolinpat
- Year and Model: 1997 850 T-5
I have a question about one of your photos. In 15.jpg which shows the old PCV connections, there's a hose in front of the two PVC hoses. It runs right under the purple tubing in the photo. Where does the other end of that wind up?
I've got mine apart, and with some delays because of ordering parts, I don't remember where that goes, and I didn't get a good before photo or video as I did my tear down.
If anyone has a photo of where the other end goes, that's better for me, but a description also helps.
Thanks.
Thanks.
- Has thanked: 316 times
- Been thanked: 531 times
That hose is the fresh air hose for the TCV. It connects to the "blue" port on the TCV.shaolinpat wrote: 05 Oct 2019, 14:41 I have a question about one of your photos. In 15.jpg which shows the old PCV connections, there's a hose in front of the two PVC hoses. It runs right under the purple tubing in the photo. Where does the other end of that wind up?
Thanks.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I used my wife's old Kobo and followed this video, I didn't have to remove the air intake or release the gas line (just swung it out of the way).
I didn't modify the hoses but if the rigid plastic hose breaks, I know understand how to replace it with a rubber hose, if we keep the car that long to find out.
Few pointers:
1)Wobble extensions are a must, UV joints can be a pain to use on the manifold. I had no problems with the awkward manifold bolts using wobble extensions. $20 will save your sanity.
2)No need to raise the vehicle, everything can be accessed from on top. I raised the vehicle on a ramp but it wasn't needed. It made putting the fuel rail bracket very difficult, I had to stand on the engine to get to it.
3)Get yourself a good flexible head ratchet, it will make removing the dipstick tube bolt and underside manifold bolt easy.
4)Few painful items:
a) starting the left most canister bolt was a pain, tape the socket to the bolt, it took me a while to get it started. Not much else you can do.
b)If you follow this method, passing the PCV line to the intake hose is a bit tricky, I taped both hoses together to pass it through the brackets and had to bend them slightly.
5)Spray the injectors prior to removing with silicone so they do not release from the fuel rail and lubricate them with silicone grease when re-installing.
6)Take this time to clean the intake manifold with brake clean and spray onto the valves. My manifold had some baked on oil which I cleaned off.
Curious if others have tried the method in the FCP video.
Few pointers:
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
Great work, and I appreciate the effort. Just a word of warning to people reading a DIY like this or watching a video online: Your car may not be the same as the one pictured. This is a general comment. I have one 1998 non-turbo and a 1999 that is not only a turbo but is a 2.3 liter T5 high pressure turbo. I would make two recommendations:
1. Posters of DIYs: Specify exact model year and mechanical specs of your car early in the video or PDF.
2. People Working On Your Cars: There are a lot of model difference between specific cars, although many "typical" cars were sold and are therefore somewhat "generic" in a manner of speaking.
My 99 T5 has MANY differences due to model year and engine type from my 98 V70. Evaporative emissions and PVC plumbing on my cars have been REAL Do It Yourself operations that bore no resemblance to the helpful guides I often rely upon.
All U.S. market models.
All running and on the road.
'99 was the first year of the "RN" engines, they were updated in several ways. A lot of DIYs don't specify if it was a -1998 or 1999+ model, but you'll have to train yourself to spot the differences. For me, it's easy to tell... engine covers are different, '99+ used coil on plug rather than distributor ignition, '99+ turbos have exhaust VVT, '99.5+ NAs have intake VVT, '99+ use a different intake manifold with an electronic throttle body (NAs retained the older style manifold, but with the ETM) and several other differences. But not everyone has owned and worked on as many P80s as me, so it's good to do a little research and keep these things you mentioned in mind while reading a thread or watching a video DIY!Eddystone wrote: 28 Oct 2019, 18:46 Great work, and I appreciate the effort. Just a word of warning to people reading a DIY like this or watching a video online: Your car may not be the same as the one pictured. This is a general comment. I have one 1998 non-turbo and a 1999 that is not only a turbo but is a 2.3 liter T5 high pressure turbo. I would make two recommendations:
This thread can be helpful, Abscate has posted lots of good info for the differences on 1999+ P80s. viewtopic.php?f=1&t=78795
- Been thanked: 4068 times
Link to the 1999 PCV DIY by mike alder, there are several changes in the 1999 of course, and turbo/ NA are different , too.
viewtopic.php?f=1&t=55413
This is also linked in the “ Bastards thread” in the General topics sticky at top
- Eddystone
And as I am sure you know, when you have a '99 with a 2.3 liter T5, a lot of DIYs (well done as they may be) simply do not apply. It helps if the DIY producers specify the year and mechanical specs of the car they are using in the video. That was my main suggestion.abscate wrote: 29 Oct 2019, 04:57 Link to the 1999 PCV DIY by mike alder, there are several changes in the 1999 of course, and turbo/ NA are different , too.
- 1351 Views
Last post by JIMMYCNOTES
- 1589 Views
Last post by CIK7
- 861 Views
Last post by aartzer
- 2536 Views
- 9 Replies
- 2867 Views
